DC current from an armature and converting AC to DC....
In summary, converting a/c to d/c can be done using diodes and an exciter circuit. Older cars used to have their electrical systems connected to the positive terminal going to ground as well, but that is no longer the case with modern electronic components.
Hadron
I cannot find answers to this on the internet. Can a d/c be made using an armature? How?
How does one convert a/c 2 d/c (or d/c to a/c)
thirdly, why does the band a/c d/c come up as the first result on google?
(don't answer the last question.)
An armature is a set of coils connected together. If AC is induced in the armature by an alternating magnetic field, that AC typically gets converted to DC via a mechanical commutator.
To convert DC to AC, an inverter is used. An inverter may consist of a motor-generator set, or more commonly done electronically with an array of switching transistors.
Well actually, you convert a/c to d/c using diodes, and an exciter circuit, for the outer field winding's, that need to be mounted in a heat sink. Think about a common car alternator. The sine wave of the electric pulses, are clipped, by the diode board, to use only the positive pulses, the negative pluses are shunted to ground, hence the heat sink, and the number of pulses per rotation, of the spinning armature, inside the outer field winding's, determines the smoothness, of the final d/c output. In reverse, a transistorized circuit board is used, also in a heat sink, to take the steady d/c current, clip it, invert half of it, at the required frequency, of say our 110- 120 cycles/ second. Thank goodness, and we should all give a minute of silence, to the first "flying wire" transistor,and the diode, least we be driving around, plagued by vacuum tube boxes the size of a bread box's in our cars.
They used to have car vacuum tube radio that size, then they went to miniature vacuum tubes and the radios became a little bit smaller.
Before the alternator automobiles had a DC generator to charge the battery and provide current for the headlights and all that jazz.
256bits said:
They used to have car vacuum tube radio that size, then they went to miniature vacuum tubes and the radios became a little bit smaller. Before the alternator automobiles had a DC generator to charge the battery and provide current for the headlights and all that jazz.
I'm well aware of this, in my fairly advanced age, but we were talking about conversions of currents. Lot's of old cars use to have their electrical systems w/ the positive terminal going to ground also, but it was the advent of modern electronic components, that allowed us to use alternators, instead of the generators, and mechanical regulators, w/ their numerous problems, such as brush ware, commutator ring burn out, regulator point pitting/ burn out, regulator hold down coil burn out, and the like..
Likes 256bits
That was the fun part. At least one could feel they were doing something to tune up their vehicle.
I really miss the carburetor freezing up in winter. and the smell of starting fluid.
Or sticking a screwdriver in the throttle, just to show your girlfriend you knew what you were doing when it wouldn't start.
Those were the days.
I think I am really getting off topic.
Related to DC current from an armature and converting AC to DC....
1. What is an armature in a DC current?
An armature is a component found in a DC motor or generator that is responsible for producing the magnetic field necessary for converting electrical energy into mechanical energy. It is typically made up of a series of coils of wire wrapped around a metal core.
2. How does an armature produce DC current?
An armature produces DC current by rotating within a magnetic field, which creates a changing magnetic flux. This changing flux induces an electromotive force (EMF) in the armature coils, causing an electrical current to flow through the circuit.
3. What is the difference between AC and DC current?
The main difference between AC (alternating current) and DC (direct current) is the direction of the flow of electrons. In AC, the electrons flow back and forth, constantly changing direction, while in DC, the electrons flow in one direction only. AC is used for long-distance power transmission, while DC is commonly used in electronics and batteries.
4. How is AC converted to DC?
There are several methods for converting AC to DC, but the most common is through the use of a rectifier. A rectifier is an electronic device that converts AC to DC by using a series of diodes to block the negative portion of the AC wave, leaving only the positive portion to pass through. This results in a pulsating DC current, which can then be smoothed out using a capacitor.
5. What are the advantages of converting AC to DC?
One of the main advantages of converting AC to DC is the ability to control the amount of voltage and current in a circuit. This is crucial in many electronic devices, as different components may require different levels of voltage or current to function properly. Additionally, DC power is more efficient for many applications, and is often used in small electronic devices such as smartphones and laptops.
