DC equivalent circuit of CB transistor?
In summary, the collector diode is taken as a current source in the equivalent circuit of a DC model of a CB transistor because the collector is typically considered a current source in any configuration, as long as there is an emitter resistor and a stable voltage on the base. This provides negative feedback to prevent too much emitter current from flowing. Additionally, in the CB configuration, the output is at the collector node and the small-signal equivalent model shows the source delivering an output current (Ic) at this node.
abhijath
figure 1 shows dc model of CB transistor, why is it that collector diode is taken as current source in equivalent circuit, why not emitter is also taken as current source ?
Generally the collector in any configuration is considered a current source provided there is an emitter resistor and a stable voltage on the base. The emitter resistor provides negative feedback. If too much emitter current is flowing the voltage across the emitter resistor rises which in turn reduces the base-emitter voltage and of course this moves the transistor slightly more towards off.
I rather think that the answer has nothing to do with an emitter resistor, which might be there or not.
In CB configuration the OUTPUT is at the collector node - and the small-signal equivalent model shows the source that delivers an output "signal" at this node.
And the "signal" is identical to a current (Ic).
FAQ: DC equivalent circuit of CB transistor?
What is a DC equivalent circuit of CB transistor?
The DC equivalent circuit of a CB (common base) transistor is a simplified representation of the transistor's behavior in a direct current (DC) circuit. It includes the components that affect the transistor's DC characteristics, such as the base-emitter and collector-emitter junctions, base and collector resistances, and the DC voltage sources.
Why is a DC equivalent circuit of CB transistor used?
The DC equivalent circuit is used to analyze and predict the transistor's performance in a circuit without having to consider the complex internal structure of the transistor. It allows for easier calculation of DC voltages and currents, and helps in designing and troubleshooting transistor circuits.
How is a DC equivalent circuit of CB transistor created?
To create a DC equivalent circuit, the transistor's internal structure is simplified and replaced with its equivalent circuit elements. The base-emitter and collector-emitter junctions are replaced with diodes, and the base and collector resistances are included. The DC voltage sources represent the voltage drops across the diodes.
What are the key components of a DC equivalent circuit of CB transistor?
The key components of a DC equivalent circuit of CB transistor are the base-emitter and collector-emitter diodes, the base and collector resistances, and the DC voltage sources. These elements determine the transistor's DC characteristics, such as its base and collector currents, and its voltage gain.
How does a DC equivalent circuit of CB transistor differ from an AC equivalent circuit?
The DC equivalent circuit only considers the transistor's behavior in a DC circuit, while the AC equivalent circuit takes into account its performance in an alternating current (AC) circuit. The AC equivalent circuit includes additional elements, such as capacitors, to represent the transistor's capacitance and its response to AC signals.
