DC generation back during Edison
In summary, DC generation during Edison's time was a heated debate between those advocating for AC and those advocating for DC. AC won the battle because it was more practical for transmission purposes.
cmos
367
DC generation back during Edison...
Hi all,
As most EE's know, back in the late 1800's, there was a debate on how electricity should be generated and distributed. Edison was the advocate of distributing DC electricity (since he owned all the appropriate patents) while Westinghouse and Tesla advocated the use of AC electricity. Clearly history was kind to Westinghouse and Tesla in this regard.
I am wondering though, how did Edison generate his form of electricity? I simply cannot imagine "huge vats" of galvanic cells distributing electricity to a nearby town.
Regards!
DC generators aren't very different from AC generators - at least in the technology needed to build and operate them.
DC power distribution is not practical over long distances. Tesla knew this and convinced George Westinghouse of the practicality of AC. This is pretty thoroughly covered in popular accounts of the AC-DC battle.
Instead of using an alternator driven by a steam engine to give AC, he used a dynamo driven by a steam engine to give DC.
The problem with DC is that you can't use transformers to increase or decrease the voltage, which is what makes grid power transmission so much more efficient by reducing the I*2R power loss in the conductors.
Long distance DC does have some advantages. Especially if you are tying different power grids together or you have underground or underwater cables.
But you need modern solid state gear to efficently convert DC voltages.
My point was that if electrical distribution systems were going to be built to provide distant homes and businesses with power, AC was the only practical way. The transmission lines could be much longer and much smaller with less loss if you stayed with AC. Yes, you needed step-up and step-down transformers to make long-distance transmission practical, but Tesla knew that it could be done, and Westinghouse had faith in him. I figured that everyone knew the history of the AC-DC battle and the practicalities that determined the winner.
I know - I was just adding one of those thread hijacking off-at-a-tangent exceptions for which PF is famous!
The politics and dirty tricks that determiend the winner are also interesting.
If there were a practical way to "transform" DC voltages up and down, wouldn't it be more practical for transmission purposes? It was my understanding that HV AC power emits a lot of EMF radiation which has interference issues and line loss. Also, wouldn't it make sense to feed houses AC instead of DC? This would mean almost all electronic equipment wouldn't need bulky power supplies.
There is a way to transform DC up & down...
It's called a static inverter.
The power line under the English Channel that connects the UK power system to France uses DC to avoid having to synchronise the generators on either side of the link.
This possibility didn't exist before the advent of high power semiconductors.
According to a wikipedia article http://en.wikipedia.org/wiki/High-voltage_direct_current , HVDC lines can be much longer and much smaller than AC lines with less loss. What is the reasoning behind your idea?
quote from wikipedia:
The advantage of HVDC is the ability to transmit large amounts of power over long distances with lower capital costs and with lower losses than AC. Depending on voltage level and construction details, losses are quoted as about 3% per 1000 km. High-voltage direct current transmission allows efficient use of energy sources remote from load centers.
Long undersea cables have a high capacitance. While this has minimal effect for DC transmission, the current required to charge and discharge the capacitance of the cable causes additional I2R power losses when the cable is carrying AC. In addition, AC power is lost to dielectric losses.
HVDC can carry more power per conductor, because for a given power rating the constant voltage in a DC line is lower than the peak voltage in an AC line.
Your example is application-specific. Read the material you linked to.
Then consider how Edison could have managed to transform HVDC to usable (safe) voltages at the user end. Not possible at the time - the technology did not exist. For the time, the available, technology, and the application (efficient, long-distance transmission of power) AC was clearly superior to DC.
DC generators are like DC motors. They have commutators which 'mechanically' convert the induced AC into DC. These days in cars.. simpler and more reliable alternators are used and simiconductor rectifiers convert the AC to DC.
DC genertors don't produce a smooth output like a battery but DC with a lot of AC ripple.
http://www.koehler.me.uk/animation/e_and_m_dc_gen_1.htm
FAQ: DC generation back during Edison
How did Edison generate DC electricity?
Edison generated DC electricity through the use of a dynamo, which is a device that converts mechanical energy into electrical energy. The dynamo consisted of a rotating magnet and a stationary coil of wire, which created a magnetic field that induced a current in the wire.
What were the advantages of DC electricity during Edison's time?
DC electricity was the primary form of electricity during Edison's time and had several advantages. It was simple and easy to generate, and could be used for a variety of applications such as lighting and motors. DC also had a relatively stable voltage, making it suitable for long-distance transmission.
What were the main challenges of DC electricity during Edison's time?
One of the main challenges of DC electricity during Edison's time was its limited range for transmission. Due to the use of low voltage and the lack of efficient transformers, DC electricity could only be transmitted over short distances. This made it difficult to supply electricity to rural areas and larger cities.
How did the development of AC electricity impact DC generation during Edison's time?
The development of AC electricity, pioneered by Nikola Tesla and George Westinghouse, posed a significant challenge to DC generation during Edison's time. AC electricity could be transmitted over longer distances and at higher voltages, making it more efficient and cost-effective. This led to the eventual decline of DC electricity as the dominant form of electrical power.
Is DC electricity still used today?
DC electricity is still used today, but its usage is limited compared to AC electricity. It is primarily used in smaller electronic devices such as batteries, smartphones, and computers. However, for large-scale power generation and transmission, AC electricity remains the preferred method due to its efficiency and lower costs.
43K
9K
11K
