DC Imperfections of a Real Op Amp
In summary: JEDEC...datasheets. They will list these values for opamps. Compare and contrast the input bias currents between those two opamps. And are the input offset voltages different at all?In summary, the input offset voltage and current for the TL084 are different from the LM324. The offset voltage for the LM324 is positive with a max value of 2.5mV, while the offset voltage for the TL084 is negative with a max value of -2.5mV. The input bias current for the LM324 is 100nA, while the input bias current for the TL084 is 10nA.
dudforreal
116
A certain op amp has the maximum offset voltage magnitude of Vos = 2 mV, the maximum bias current of Ib = 100 nA and the maximum offset current magnitude of Ios = 10 nA. The op amp is used in the noninverting amplifier shown in the diagram below. Find the worst-case DC output voltage range if vi = 0 and Rbias = 0. What should be the value of Rbias to cancel the effect of bias currents? Repeat part 1 for vi = 0 and Rbias calculated in part 2.
The attempt at a solution
I have no idea with the question but I calculated output voltage as 22mV using
V0 = -(1+R2/R1)*Voff
That's a good start. But you also need to include the effects of the input offset current.
Figure out visually how to get the worst case offsets each way (both positive and negative) -- which way should the input offset current point in order to add to a positive input offset voltage? Calculate the maximum output voltage that results. Then which way should theinput offset current point in order to add to a negative input offset voltage? Calculate the maximum output voltage that results. Then subtract the two output voltages to see what the maximum output deviation is due to the finite input offset voltage and input offset current.
Then the 2nd part of the question is a classic circuit question in opamp circuit design. Think about why the input offset current generates an input offset voltage term...
EDIT -- BTW, it may help you to look at a typical opamp datasheet, to see how the input offset voltage and current are defined...
I'm still confused can you guide through what to do as the first step
Please link to a typical opamp datasheet, and post your specific questions about what you don't understand about input offset voltages and currents...
This all works best if you put a lot of effort forth in working on your schoolwork problems...
That's because I barely understand these problems and how to approach them
To compute the effects of bias and offset currents, pretend the op amp offset voltage = 0 and compute the output voltage based on elementary Kirchhoff equations.
Remember that Ios = Ib2 - Ib1.
The total effect of Ios, Ib and Eos is then the addition of these individual effects,worst-cased.
Can you specify where is Ib1 and Ib2?
Sure. Ib1 is the current into (or out of) the - input lead, and Ib2 is the current into (or out of) the + input lead.
Ideally, Ib1 = Ib2 but because of imperfections, Ib2 - Ib1 = Ios.
Isn't Ib1 = 0 because resistance is infinity
No. This is a dc current. The ac impedance may be (essentially) infinite, but there is still a dc current flowing all the time. That's to keep the input transistors alive. This current does not change with either dc or ac input voltage (as far as you're concerned).
How would you get the Kirchoff equations?
Surely you can write the sum of currents = 0 at V(-). First, set V(+) = 0. Remeber Ib1, Ib2 and Ios = Ib2 - Ib1 are all dc currents. They are constants.
sorry but I can't really picture where the currents are.
Zero effort on your part is not allowed. here. Use the hints and advice you're received so far here, and look at the datasheet for a typical opamp. If you want us to help you, you MUST show some effort on your part.
Where can you find a datasheet? I really got no clue to this question.
Please Google LM324 datasheet.
And the also Google TL084 datasheet.
Do the datasheets show the models for the input offset voltage, input bias currents, and input offset current?
You might also search at the National Semiconductor website or Maxim's website for application notes on opamp offset currents and voltages. The manufacturers are very motivated to help you understand practical design considerations.
yes they are different.
Take the opamp as being ideal, an then place a current source between zero volts and the -ive input terminal on the opamp. Can you analyze that circuit?
Where is the zero volts?
In your first post in the opamp circuit figure, zero volts is the ground symbol at the bottom. The horizontal line symbol below the bottom resistor.
Please read through this tutorial page on opamps:
http://en.wikipedia.org/wiki/Operational_amplifier
It covers the basics of ideal opamps, and then describes the other things that you need to consider for real opamps (like the input offset voltage and offset current that this problem is asking about).
I hate to muddy the water here but if I'm not censored I would urge you NOT to got to a data sheet. You need to look more into your textbook instead. Data sheets are meant for professionals and the very well informed. You would just be more confused by the plethora of informartion therein, most of which is irrelevant to your present problem.
On the other hand, application notes could be helpful. But if you're using a textbook in your course on op amps etc., that is the most likely best source for you.
Judging by the difficulties that dudforreal seems to be having, you may be right about the datasheet approach.
@dudforreal -- If you can find a copy of the textbook "The Art of Electronics" by Horowitz and Hill in your school library, check out Chapter 3 where it discusses opamps. It has a pretty clear description of the input bias currents and input offset voltage error terms. There is also a table of typical opamps (although the list is a bit dated), showing these error terms that we have been discussing.
Is there a simple method to doing this question because I don't have that textbook and my textbook is not very useful :cry:
No. I agree with berkeman: read the wikipedia article.
We have given you many resources to solve this homework problem, and you have shown ZERO effort. This thread is closed.
FAQ: DC Imperfections of a Real Op Amp
What is a DC Imperfection of a Real Op Amp?
A DC Imperfection of a Real Op Amp refers to the small deviations or errors in the performance of an operational amplifier (op amp) when operating in DC conditions. These imperfections can affect the accuracy and stability of the op amp's output.
What are some common DC Imperfections of a Real Op Amp?
Some common DC Imperfections of a Real Op Amp include offset voltage, offset current, input bias current, and input offset voltage. These imperfections can lead to errors in the output voltage and can be caused by manufacturing variations, temperature changes, and other environmental factors.
How do DC Imperfections affect the performance of an op amp?
DC Imperfections can affect the accuracy, linearity, and stability of an op amp's output. They can also cause distortion, noise, and other unwanted effects in the output signal. In some cases, DC Imperfections can even lead to the failure of the op amp.
What are some ways to minimize DC Imperfections in an op amp?
To minimize DC Imperfections, op amps are designed with special circuitry that compensates for these imperfections. This can include offset nulling, trimming, and other techniques. Additionally, using high-quality components and proper circuit design can also help reduce DC Imperfections.
Can DC Imperfections be completely eliminated in an op amp?
No, it is not possible to completely eliminate DC Imperfections in an op amp. However, through careful design and selection of components, these imperfections can be minimized to a level that does not significantly affect the op amp's performance.
