binbagsss
- 1,265
- 11
So for ## \lambda > 0 ##, these 3 solutions for ## k=-1,0,1 ## differ only by a coordinate transformation, and describe the same space-time.## \lambda <0 ##: ## k=-1 ## :
## a=\sqrt{\frac{-3}{\Lambda}}sin(\sqrt {\frac{-\Lambda}{3}}t) ##
## \lambda>0 ## :
## k=-1 ##: ## a=\sqrt{\frac{3}{\Lambda}}sinh(\sqrt{\frac{\Lambda}{3}}t) ## \\
## k=0 ##: ## a\propto e^{(\pm\sqrt{\frac{\Lambda}{3}}t)} ## \\
## k=1 ##: ##a=\sqrt{\frac{3}{\Lambda}}cosh(\sqrt{\frac{\Lambda}{3}}t) ##Questions
I've read on a few sources that the scale factor grows exponentially, but surely this is just in a particular coordinate chart, as it is only apparent , above, in the ##k=0## solution.
Probably a stupid question, but different coordinate charts suggest different dynamics of ##a(t)##, so which is the 'true' relation?
I.e- Is the de-sitter space geometrically open, closed or flat?
Anti de-sitter space geometrically? I'm guessing it's called anti for a reason
The exponential solution for ##k=0## has a ## \pm ##, how is this possible , don't they describe completely different things - contraction and expansion?
Thanks .
## \lambda>0 ## :
Thanks .
