Dealing with Hollow and Solid shafts....
  • Thread starter Thread starter pressurised
    Solid
In analyzing a bar fixed at one end with a hollow section transitioning to a solid section, static equilibrium can indeed be applied to determine the reaction torque, similar to a bar with varying diameters. The approach involves segmenting the bar and utilizing torsion formulas to assess shear stress and angle of twist. By creating free-body diagrams for each segment, the torque on the uniform part of the composite beam can be calculated, allowing for the determination of shear stress in the hollow section. This method effectively addresses the complexities introduced by the differing geometries of the shaft. Overall, the principles of mechanics remain consistent regardless of the shaft's configuration.
pressurised
When dealing with a bar (fixed on one end), if it is hollow for a certain length from the edge and then turns solid up until the fixed point, can the condition of static equilibrium be used to find the reaction torque, just like you would of a bar with 2 different diameters.
(Assuming all this is of the same material and a torque is provided only on the non fixed end right at the edge)
To me it seems like the same method can be used for this, dividing the bar into segments to use pure torsion formulas and find the variation of shear stress and angle of twist.
Sure, you can split up any object and make free-body diagrams of the components. From the free-body diagrams, you can find (for example) the torque on a uniform part of the composite beam and thus the shear stress in the thin wall.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 19 ·
