MHB Debbie's question from Facebook on interest rates
  • Thread starter Thread starter Jameson
    Interest
To determine the interest charged on a balance of $20,323.64 at an annual interest rate of 10%, it is important to clarify whether the interest is compounded or simple. If calculated annually, the interest can be added to the balance either in January or December, resulting in a total of $2,400 in payments made throughout the year. The ending balance will depend on when the interest is applied, but it will include the initial balance, the payments, and the interest accrued. If interest is charged monthly, further clarification is needed on whether to use simple or compound interest. Understanding these factors will help in accurately calculating the interest and final balance for future reference.
Jameson
Insights Author
MHB
I'm needing help w/ an accounting issue that deals with applying interest annually. The interest rate is 10%. It doesn't say if it's compounded or simple so which is to be used?
If you start with a balance of \$20323.64 in Jan, and make twelve monthly payments of \$200 each (total \$2400) how much $ in interest is charged, when is it applied (Jan, monthly, or Dec etc?) and what's the ending balance for the year?
Please help me out, and explain your answer so that I'll know how to do it next time ok? Thanks!
Mathematics news on Phys.org
Hi Debbie, :)
Looking forward to seeing you on Math Help Boards. :)
I don't think it matters whether the interest is simple or compound if it is applied in January or December on an annual basis provided that you want to find the balance at the end of the first year. Suppose the interest is calculated each January. At the moment of calculation you have a balance of \(\$ 20323.64\) in the account and the interest gained in the first year is therefore, \(\$ 20323.64\times \frac{10}{100}\). So at the end of the first year you will have a balance of,
\[\$ 20323.64+\$2400+\left(\$ 20323.64\times \frac{10}{100}\right)\]
Similarly if the interest is calculated in December, you'll have to find the total amount of money in the account in December and perform the calculation as above. If the interest is charged monthly, then it should be given whether to use simple or compound interest.
Kind Regards,
Sudharaka.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
