Decelerating distance and magnitude of impulse of a car
In summary: So in this case, if we have a car that is moving at a certain velocity and then we apply an acceleration, the car will move faster.
Juls808
A 1,000kg car traveling with a velocity of +20.0meters per second decelerates uniformly at -5.00 meters per second per second until it comes to rest.
What is the total distance the car travels as it decelerates to rest?
What is the magnitude of the impulse applied to the car to bring it to rest?
What exactly do you require help with? I mean, where in your working did you get stuck?
I don't know which equations to use.
You have a velocity and an acceleration. How do those relate to displacement? (or distance in this case)
So it would be velocity=distance/time and it would be that simple because its uniform? And impulse=force*time?
It can't be that simple because that gives me a distance of 100 meters.
You have to take the (de-)acceleration into account. So you're going to need to relate your acceleration to distance, with having an initial velocity in the opposite direction. (so you could take your acceleration as negative, and your velocity as positive)
Why don't you show us your calculations step by step? That way we can pinpoint any mistakes. Just telling us you found a distance of 100 meters (which is not correct) with no explanation whatsoever about how you got to that number is not very enlightening. And please write the equations down before plugging in any values so we know what equation you're using. (By the way, do that on your homework and tests as well. Your professor will greatly appreciate).
You're losing me. Impulse is a change in momentum, and is also ##\int \vec{F}dt## but I have no idea why you're using that. What in this problem says, "use momentum" to you? (Other than the mass that's given, keep in mind physics profs are tricky ;-] )
Ok so you figured out that ##|v| = \frac{\Delta x}{\Delta t}## which works for this, but really what you want is ##\vec{v} = \frac{d\vec{x}}{dt}## and you have another quantity in there, acceleration ##\vec{a}##
Now how does acceleration relate to what we have?
FAQ: Decelerating distance and magnitude of impulse of a car
1. What is decelerating distance?
Decelerating distance is the distance a car travels while slowing down or coming to a stop. It is the distance between the point where the brakes are applied and the point where the car comes to a complete stop.
2. How is decelerating distance affected by the speed of the car?
The higher the speed of the car, the longer the decelerating distance will be. This is because at higher speeds, the car has more momentum and it takes longer to slow down and come to a stop.
3. What factors influence the magnitude of impulse experienced by a car during deceleration?
The magnitude of impulse experienced by a car during deceleration is influenced by the mass of the car, the speed at which it is traveling, and the duration of the deceleration. A heavier car traveling at a higher speed and decelerating over a longer distance will experience a greater impulse.
4. How does the braking system of a car affect decelerating distance?
The braking system of a car plays a crucial role in determining the decelerating distance. A well-maintained and efficient braking system can reduce the decelerating distance by applying the brakes more effectively and bringing the car to a stop in a shorter distance.
5. Can decelerating distance be reduced by changing the tires of a car?
Yes, the type and condition of tires can affect the decelerating distance of a car. Tires with better traction and grip can help the car slow down more efficiently and reduce the decelerating distance. Additionally, keeping the tires properly inflated can also improve the braking performance of a car.
