Decimal representation of real numbers
In summary, the problem statement on page 31 of Apostol's Calculus vol. I shows how to construct a set S of numbers using a positive real number x. This set is nonempty and bounded above, and therefore has a least upper bound b. It is then shown that x = b by considering the possible cases of b being less than, equal to, or greater than x. A proof by contradiction is used to show that the first and last cases are impossible, and thus the only remaining possibility is that x = b. This conclusion is reached using basic concepts of the real number system and no limits or squeeze theorem are needed. The proof also uses the Archimedean property of real numbers and the fact that for every real
marcin w
I'm doing self study out of Apostol's Calculus vol. I and I got stuck trying to prove what the author writes is easy to verify, but I can't get my head around it. Basically, this is the problem statement from page 31, last paragraph:
Given a positive real number x, let a0 denote the largest integer <= x. Having chosen a0, we let a1 denote the largest integer such that
a0 + (a1)/10 <= x.
More generally, having chosen a0, a1,...,an-1, we let an denote the largest integer such that
a0 + (a1)/10 + ... + (an)/10^n <= x.
Then let S denote the set of all numbers obtained this way for n = 0, 1, 2, ...
I understand the construction of set S because I have proven before that the greatest integer in a positive real number exists, hence the set is nonempty. I also see that
a0 + (a1)/10 + ... + (an + 1)/10^n is an upper bound, so this property with the nonemptyness of S guarantees that S has a supremum, say b. The punchline is that I want to verify that x = b.
I'm not trying to prove here that .999... = 1. I know that and can prove it using geometric series and algebraic arguments. I want to rigorously prove the above using just the bare essentials (ie. axioms) of the real number system.
I was thinking of arguing by contradiction that x > b or x < b is impossible. My other thought for a rough sketch was that to prove that the infinum of the set for decimal expansion of x - b is 0, but I don't know where to start really. Thanks in advance.
Let s_n = a0 + (a1)/10 + ... + (an)/10^n. Then {s_n} is a bounded, nondecreasing sequence of reals. It must converge to supS = b, i.e. lim s_n = b. We also know that:
s_n <= x <= s_n + 1/10^n
Applying the sequeeze theorem, we see that:
lim s_n <= x <= lim s_n
=> x = lim s_n = b.
Thanks for the reply, but I was looking for something even more elementary - no limits and no squeeze theorem. Is this proof possible to do with even more basic concepts? I'm curious because Apostol is very thorough and I'm confident he wouldn't write this if it couldn't be done with the material so far covered (which is before differentiation and integration are even introduced).
It's clear that all the numbers in the sequence are <=x, so if you can show their limit is >=x, you're done. To do this, assume its <x, and derive a contradiction (ie, show you haven't picked the a_n correctly).
I think I have worked out a correct proof. I would appreciate it if anyone could review this and criticize if necessary.
I have already established that S is nonempty and bounded above so I will not dwell on this fact anymore. As in my first post, by the law of trichotomy, the least upper bound b is one of the following:
b < x, x = b or b > x
and I will show by contradiction that the first and last are impossible.
Suppose that b < x. Choose a c such that 0 < c < x - b, or written equivalently as (1) b < b + c < x. By the Archimedean property of real numbers, there exists a positive integer n such that (*) 1/(10^n) < c (Proof on the bottom of this post). Since b is an upper bound, it follows that:
a0 + (a1)/10 + ... + (an)/(10^n) <= b. Combining this with (*), we have
a0 + (a1)/10 + ... + (an)/(10^n) + 1/(10^n) < b + c
or
a0 + (a1)/10 + ... + (an + 1)/(10^n) < b + c.
Here we have a contradiction because an was supposed to be the greatest integer such that the decimal expansion is <= x, but we have found that an + 1 is an even greater positive number such that the expansion is <= x due to (1).
If b > x, then choose a c such that 0 < c < b -x or x < c + x < b. It is clear that c + x is another upper bound for S that is less than the least upper bound b, which is a contradiction
(*) To prove that that there exits a positive n such that 1/(10^n) < y, I use the fact that for every real number x, there exists a positive integer such that x < n and by induction I will show that n < 10^n for every n.
Let A(n) = n < 10^n.
A is clearly true for 1.
Now assuming that A(k) = k < 10^k is true, I multiply both sides by 10 to obtain
10k < 10^k * 10 or (1) 10k < 10^(k+1)
Now, (2) k + 1 < 10k is true because 10k - (k + 1) = 9k + 1 > 0.
By the transitive property of inequalities, (1) and (2) combine and we obtain
k + 1 < 10^(k+1), as asserted.
Therefore we have that x < n < 10^n or x < 10^n. Replacing x by 1/y (where y > 0), we have
1/y < 10^n or 1/(10^n) < y, just as stated.
QED?
Thanks in advance.
Yea, you've proven it in painstaking detail. Normally you can leave out well known results you've already seen the proof of. Still, you've only shown the sup of the sequence is x, not that it converges to x. The proof that the first implies the second in this case is simple, but if you're going to include all the other details, you might as well throw that in.
FAQ: Decimal representation of real numbers
1. What is the decimal representation of a real number?
The decimal representation of a real number is a way of expressing a number in base 10, using the digits 0 to 9. It includes a whole number part, a decimal point, and a fractional part.
2. How does the decimal representation of a real number differ from other number representations?
The decimal representation of a real number is unique because it uses base 10, while other number representations like binary or hexadecimal use different bases. This means that the placement of digits in a decimal number has a different value than in other number systems.
3. Can all real numbers be represented in decimal form?
No, not all real numbers can be represented in decimal form. Some numbers, like irrational numbers such as pi or square root of 2, have infinite decimal representations that never repeat or end. These numbers are called non-terminating and non-repeating decimals.
4. How accurate is the decimal representation of a real number?
The accuracy of the decimal representation of a real number depends on the number of decimal places used. The more decimal places used, the more accurate the representation will be. However, due to the nature of computers and rounding, the decimal representation of a real number may not be entirely accurate.
5. How is scientific notation related to the decimal representation of real numbers?
Scientific notation is a way of writing very large or very small numbers using powers of 10. It is closely related to the decimal representation of real numbers because it uses the same base 10 system. In scientific notation, the decimal point is placed after the first digit and the remaining digits are multiplied by a power of 10. This is similar to how the decimal representation of a real number works.
