Decoherence and Consciousness: Exploring Branch Selection in Quantum Mechanics
  • B
  • Thread starter fanieh
  • Tags
    Decoherence
In summary: No.The double slit experiment is a classic example of a mixed state.Without the concept of decoherence, there is still the problem of outcome prior to decoherence or after it, correct?Yes.You need to study it more - the problem in very interpretation dependant - in some its a big issue - in others trivial.
fanieh
274
After decoherence, is there something wrong if the branch chosen would be selected by consciousness?
So there is ambient consciousness that select default branches and human consciousness can bias which branches chosen? Is there any experiment that has excluded this possibility?
No. Its just has zero experimental support and is far too new age weird for most peoples taste. That of course means nothing - but the experimental thing is another matter.
And it really must be asked - why do you want QM to be weirder than it already is? Just what exactly do you gain?
Thanks
Bill
I have no idea what is ambient consciousness. :wideeyed:
Likes bhobba
Thanks
Bill
I'm thinking of the branches before and after decoherence.
If the branches all exist before decoherence.. then only one branch is selected by consciousness after decoherence?
So it's like Many worlds before decoherence and one world after decoherence.
But then. Is it possible that the branches prior to decoherence already reduced to one even before decoherence.. or should the branches reduction to one only occur after decoherence in the general concept of decoherence?
This is just to get versatile in the thinking about it all.
Its an improper mixed state, how it becomes a proper one in the issue with consciousness being a very fringe explanation - so fringe I really know anyone that adheres to it.
To understand the issue see the following:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
Thanks
Bill
Thanks
Bill
There is portion inside page 31: "The problem of Outcome: Why does one perceive a single outcome among the many possible ones in equation (2.1)?"
Outcome means the branches?
But this is not related to decoherence directly.. because decoherence just explains why everything is not in superposition... even without the concept of decoherence, there is still the problem of outcome prior to decoherence or after it, correct? In other words, is the problem of outcome independent of decoherence?
That is by definition decohrerene.
The deep dark issue is how it becomes a proper mixed state ie only one output with certain probability.
MW resolves it by each output being a separate world.
Thanks
Bill
No.
Here is the STANDARD text
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
Thanks
Bill
Thanks
Bill
Before spending 6 months with your book below. Just some general ideas. Let's use actual example. In the double slit experiment.. decoherence means the electron or photon has collided with those from the environment hence the screen detector no longer shows interference. So you were saying the environmental decoherence has made the electron choose either left or right path.. so why is there the deep dark issue of how it becomes a proper mixed state.. or only one output with certain probability? Isn't it the environment photons have decohere it and therefore obviously it would produce only one output with certain probability?
Or how would the double slit experiment look like if it doesn't become proper mixed state (ie only one output with certain probability) even though environmental photons have decohere the electron? What detection pattern would result?
That's not decoherence.
In the double slit it interacts with the screen, becomes entangled with it so its a mixed state of position. The question is which 'element' of the mixed state is realized.
Do you know the difference between a pure and a mixed state? Do you know states are not really elements of a vector space but operators?
Thats
Bill
Thats
Bill
I think you understood me. I got the idea from the following that when the photons or electrons from the double slit experiments collided with the photons from the environment or "the reason why the interference term is not observed is because the electron has become entangled with the stray particles...It is this phenomenon of suppression of interference through suitable interaction with the environment that we call ‘dynamical’ or ‘environmental’ decoherence".. are you saying the following description is wrong?? If it's not wrong.. why did you say what I wrote which is based on the following was wrong (or not decoherence)?? http://plato.stanford.edu/entries/qm-decoherence/#DynDec
"There are, however, situations in which this interference term (for detections at the screen) is not observed, i.e. in which the classical probability formula applies. This happens for instance when we perform a detection at the slits, whether or not we believe that measurements are related to a ‘true’ collapse of the wave function (i.e. that only one of the components survives the measurement and proceeds to hit the screen). The disappearence of the interference term, however, can happen also spontaneously, when no collapse (true or otherwise) is presumed to happen. Namely, if some other systems (say, sufficiently many stray cosmic particles scattering off the electron) suitably interact with the wave between the slits and the screen. In this case, the reason why the interference term is not observed is because the electron has become entangled with the stray particles.[3] The phase relation between the two components of the wave function, which is responsible for interference, is well-defined only at the level of the larger system composed of electron and stray particles, and can produce interference only in a suitable experiment including the larger system. Probabilities for results of measurements performed only on the electron are calculated as if the wave function had collapsed to one or the other of its two components, but in fact the phase relations have merely been distributed over a larger system.[4] It is this phenomenon of suppression of interference through suitable interaction with the environment that we call ‘dynamical’ or ‘environmental’ decoherence."
I think you first need to understand the double slit before discussing decoherence implications:
https://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
Once you do we can discuss how decoherence applies to it.
For example wavefunction collapse has nothing to do with it - its from the uncertainty principle and superposition principle. Its got nothing to do with interactions other than the slits between siource and screen. The reason detecting at the slits destroys interference is the superposition principle no longer appllies.
Thanks
Bill
Thanks
Bill
The paper has so many dense math. I'm a layman. This thread has a B label to it. B means Beginner. Therefore I hope others who are more verbal can answer my question whether the branches are still there prior to decoherence or after it. This is because decoherence doesn't solve the measurement problem. So I'm thinking if consciousness chooses the outcome.. then it is independent of decoherence. I read that if objective collapse occurs faster than decoherence.. then there is no decoherence but only objective collapse... I'm thinking if consciousness choosing outcome is faster than decoherence or slower. (Demystifer. for sake of discussion. Ambient consciousness that choose outcomes without human consciousness simply means background consciousness that let's say is part of the universe. So it can chooses branches in default mode.. hence even without humans present.. it works.. but ignore this.. I simply want to understand about the branches before and after decoherence and whether the outcome is chosen before or after and how to do it. So those who were laymen friendly advisers.. please share your views. Bill is super super advance and I can't read 6 months of his books and papers before jus knowing a certain specific question).
fanieh said:
I'm a layman.
Ahhhhh.
I will write a easier to understand version a bit later.
Thanks
Bill
Ok - a few things.
A pure state is written as Iu>. The principle of superposition says given any two states |u1> and |u2> then |u1> + |u2> is also a possible state.
Now any pure state can be decomposed into the sum of a lot of other pure states - usually though is broken down into superposition's of position so |u> = |x1> + |x2> +++++ |xn> wjere each |xi> is a state of definite position.
Now remember I mentioned states really aren't vectors, they are operators. The operator for a pure state is written as |u><u|. In general operators are of the form ∑pi |xi><xi| where the |xi><xi| are states of exact posiotion. It turns out the probability of it having position |xi> is pi. There are a number of ways of preparing mixed states. One way is simply to take a state and randomly present it with probability pi. Such are called proper mixed states. With proper mixed states everything is sweet - objective reality exists before observation - much of quantum wierdness disappears. But that is just one way of going it. Another way is to take a state and subject it to the process of decoherence - you get exactly the same mixed state and their is no way to tell the difference - no way at all. But because its prepared differently than a proper mixed state its called an improper one. The trouble is you can't say its in the state prior to opservation - there is simply no way to tell. If not quantum wierdness remains. This is the modern version of the measurement problem. What causes an improper mixture to become a proper one. Colloquially its why we get any outcomes at all. With different interpretations like MW and BM its trivial, with others like ensemble its much more controversial - even to the point of its a problem at all.
Now to the double slit. The electron interacts with the screen and via decoherence becomes a mixed state. It registers one of the positions - the question is - why did it register a particular one?
How conciousness would come into it is anyones quess.
Thanks
Bill
Likes fanieh
bhobba said:
Ok - a few things.
Thanks
Bill
Thanks. Since in consciousness based interpretation.. ambient or background consciousness can automatically collapse wave function or else how can the universe exist before humans appear, then we may as well just talk about Objective collapse to avoid much weirdness. They say if Objective Collapse occur faster than decoherence, then there is no decoherence.. in this case.. improper mixed state turns to proper mixed state by objective collapse. But is this very statement true at all that that objective collapse can occur faster than decoherence? Is decoherence proven 100%? If true, then objective collapse can't occur faster than decoherence?
Decoherenve is proven 100% and follows from the formalism. What it means is the issue.
Objective collapse doesn't exist in the theory - only interpretations - collapse is not part of QM or the QM formalism.
There is an interpretation called GRW where it exists:
https://en.wikipedia.org/wiki/Ghirardi–Rimini–Weber_theory
Thanks
Bill
Thats
Bill
I comprehended that the electron interacts with the screen and via decoherence becomes a mixed state.. but if the electron were hit from photons from one of the slits or from the environment, there is no longer any interference... and from the paper "Decoherence of matter waves by thermal emission of radiation"
https://arxiv.org/pdf/quant-ph/0402146.pdf It is also called decoherence or environmental decoherence.. why did you state "That's not decoherence"? Is it not environmental decoherence effect?
Decoherence is a particular type of interaction:
https://en.wikipedia.org/wiki/Quantum_decoherence
The original system's wavefunction can be expanded in many different ways as a sum of elements in a quantum superposition. Each expansion corresponds to a projection of the wave vector onto a basis. The basis can be chosen at will. Let us choose an expansion where the resulting basis elements interact with the environment in an element-specific way. Such elements will—with overwhelming probability—be rapidly separated from each other by their natural unitary time evolution along their own independent paths. After a very short interaction, there is almost no chance of any further interference. The process is effectively irreversible. The different elements effectively become "lost" from each other in the expanded phase space created by coupling with the environment; in phase space, this decoupling is monitored through the Wigner quasi-probability distribution. The original elements are said to have decohered. The environment has effectively selected out those expansions or decompositions of the original state vector that decohere (or lose phase coherence) with each other. This is called "environmentally-induced-superselection", or einselection.[4] The decohered elements of the system no longer exhibit quantum interference between each other, as in a double-slit experiment. Any elements that decohere from each other via environmental interactions are said to be quantum entangledwith the environment. The converse is not true: not all entangled states are decohered from each other.
Although it must be said people often speak a bit loosely about it. For example decoherence is usually considered to be irreversible, but in explaining the delayed choice experiment I, and others say, in simple cases dechorence can be undone. Strictly speaking if it can be undone its not irreversible so wasn't decoherence to begin with. An in the double slit what happens to the electron as it travels from slit to screen is irrelevant - in fact its usually a vacuum.
What I was trying to get across in the double slit is the key decoherence occurs at the screen.
Thanks
Bill
Thanks
Bill
In the "environment" in the above description.. can you considered the screen some kind of "environment" that cause decoherence? Or is "environment" everything else except the screen?
I'm thinking the environment would encompass everything else in the universe, including the screen.
One must be careful with decoherence as it is wrongly promoted to say a quantum system is in one or another state -- it is in a superposition. For all practical purposes (FAPP) decoherence is useful for claiming the macroscopic world isn't in a superposition -- however, in principle that is not the case.
Decoherence is usually divided into measuring device and environment. The measuring device in the double slit is the screen. With electrons the environment is a hard vacuum.
You mentioned you were a beginner. That paper is NOT for a beginner.
If you want to discuss it start a new thread but I am afraid it will not be at a level that would be likely suitable.
Thanks
Bill
That's wrong and shows an admittedly common misunderstanding of superposition.
Here is not the place to discuss it - start a new thread. Suffice to say all pure states are in superposition and in a myriad of ways.
Thanks
Bill
Is Bill belief that when one outcome chosen from the mixed state, the decoherence is irreversible hence the true key decoherence?
Thanks
Bill
StevieTNZ has written 1300 messages on decoherence and spent years discussing it yet he is still wrong. Cant you write a primer on decoherence? And what paper do you mean not for a beginner.. do you mean the following paper: http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf ?
Anyway. If the screen causes the mixed state and decoherence as you stated "In the double slit it interacts with the screen, becomes entangled with it so its a mixed state of position"... then if one removes the screen, then it's in pure state? I don't have to create a separate thread just for this question. I'm understanding the above paper already.
https://arxiv.org/pdf/quant-ph/0402146.pdf is what I was referring to. It is NOT a beginner paper yet you wanted to discus its content. I gave a paper at the intermediate level: https://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
Yet it was too dense for you.
You seem to be jumping all over the place.
For completeness I will give you the beginner explanation. We will consider electrons in a hard vacuum. There is no environment just a detection screen. Just behind the slit the electron has an exact position. By the uncertainty principle it has an unknown momentum, but because its kinetic energy is known this means it has an unknown direction. it can hit the screen anywhere - the exact place being determined by decoherence. But we have two slits. That means we superimpose the two states (ie apply the principle of superposition) and when you chug through the math you find the wavefunction has interference like peaks and troughs.
It hits the screen and where it has a peak it has a greater chance of, via decoherence, of registering a position. Where it has a trough it has no chance so none will be found there. This is a little dfifferent than what you will find in a beginner text becauise it doesn't use the wave particle duality which is wrong - but that is another thread.
Consciousness is not required. One could record the result on a computer and write the result to memory. Scatter millions of copyies across the cosmos. A billion years later read the results. It would take a very peculiar view of the world to say that's when collapse occurred ie nature decided where to register the position on the screen. You could do it - but what would such a weird view gain? It can't be disproved - its a legit theory - but the vast majority of physicists, correctly, reject it aa being - well cockeyed. StevieNZ is not one of those - he has his view and is entitled to it. I have stated mine. I can't make up your mind for you - that's up to you. But by forum rules philosophy is not discussed here so if you want to pursue it take it elsewhere.
I believe your original question has been answered. If you have any further ones start a new thread, but I will no longer be contributing to this one.
Thanks
Bill
Related to Decoherence and Consciousness: Exploring Branch Selection in Quantum Mechanics
1. What is decoherence and how does it relate to consciousness?
Decoherence is a process in quantum mechanics where a quantum system interacts with its environment, causing it to lose its quantum properties and behave classically. This process is important in understanding the emergence of classical reality from the quantum world. Some theories suggest that decoherence may play a role in the emergence of consciousness, but this is still a topic of ongoing research.
2. Can decoherence explain the collapse of the wave function in quantum mechanics?
While decoherence is often used to explain the collapse of the wave function in quantum mechanics, it is important to note that it does not fully solve the measurement problem. Decoherence only describes how quantum systems interact with their environment, but it does not address the fundamental question of why a particular outcome is selected during measurement.
3. How does decoherence affect the Many-Worlds interpretation of quantum mechanics?
The Many-Worlds interpretation suggests that all possible outcomes of a quantum event exist in parallel universes. Decoherence is often seen as a mechanism for branching the universe into different branches, each representing a different outcome. However, the exact relationship between decoherence and the Many-Worlds interpretation is still a topic of debate among physicists.
4. Is there any empirical evidence for the role of decoherence in consciousness?
Currently, there is no empirical evidence that directly links decoherence to consciousness. While some studies have shown correlations between brain activity and decoherence, more research is needed to determine the exact role of decoherence in consciousness.
5. How does the concept of branch selection in quantum mechanics relate to free will?
Some theories suggest that the branching of the universe into different outcomes during measurement may be linked to the concept of free will. However, this is still a highly debated topic and there is no consensus among scientists on how decoherence and branch selection may relate to free will.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
