Decomposing the arc length of a circular arc segment
In summary, the conversation discusses finding the total distance traveled by a particle along a circular arc segment with a given radius, start angle, and end angle. The distance can be calculated using the arc length formula, and the question of finding the distance covered along the X and Y axes is also raised. The speakers suggest using an integral or breaking up the arc into smaller pieces to analyze the distances separately.
jumbo1985
A particle travels along a circular arc segment centered at the origin of the Cartesian plane with radius R, a start angle θ1 and an end angle θ2 (with θ2 ≥ θ1 and Δθ = θ2 - θ2 ≤ 2π). The total distance traveled is equal to the arc length of the segment: L = R(Δθ).
I would like to find the distance covered by the particle along the X axis and the distance covered by the particle along the Y axis.
I'm not sure how to do this unless I break up the arc at each quadrant crossing and analyze the pieces separately.
Any tips are greatly appreciated.
Mathematics news on Phys.org
Distance covered as in "if you go back and forth you count it twice"? You can write down an integral that works in general, but analyzing 2 special cases is easier.
Yes, exactly - If you go back and forth you count it twice. I'm looking for one elegant expression in terms of x and in terms of y but that may not be possible?
Related to Decomposing the arc length of a circular arc segment
1. What is the formula for calculating the arc length of a circular arc segment?
The formula for calculating the arc length of a circular arc segment is L = r * θ, where L is the arc length, r is the radius of the circle, and θ is the central angle of the arc in radians.
2. How do you determine the central angle θ of a circular arc segment?
The central angle θ can be determined by dividing the arc length by the radius of the circle. In other words, θ = L / r.
3. Can the arc length of a circular arc segment be negative?
No, the arc length of a circular arc segment cannot be negative. It is always a positive value as it represents the distance along the circumference of the circle.
4. What units should be used for the radius and central angle in the arc length formula?
The radius should be in the same units as the arc length, and the central angle should be in radians. If the central angle is given in degrees, it can be converted to radians by multiplying by π/180.
5. How accurate is the formula for calculating the arc length of a circular arc segment?
The formula for calculating the arc length of a circular arc segment is exact and always gives the correct value. However, the accuracy of the calculated value may be affected by the accuracy of the measured or given values for the radius and central angle.
