Decompressing through an underwater horn shaped tunnel
In summary, a horn-shaped tunnel would provide a safe passage from deep sea to the surface, without the need for decompression.
Jimijel
Since the Titan sub disaster I have been thinking about the issue of protecting people from the dangers of the pressure changes associated with deep sea exploration. Reading about the Byford dolphin tragedy in particular was chilling. This was just a thought experiment of mine and I was wondering how feasible it was.
So take a horn shaped tunnel of solid steel and place the wide end on the sea floor and the narrow end on the surface. If a submarine where to travel through it, if my rusty high school level knowledge of physics is correct, the hydrostatic pressure acting on it will reduce as the diameter of the horn reduces (P= pgh). So if the sub travels slowly enough for the body to incrementally adjust, could this method get people safely from deep sea to the surface?
Sorry but your physics is in fact rusty (from the salt water!). The cross section matters not at all.
Likes russ_watters and Jimijel
P=ρgh is the equation for incompressible water ignoring atmospheric pressure. More importantly, h is the depth.
Likes Jimijel
If the sub travelled slowly from the sea floor to the surface, the pressure on it is going to decrease to a safe level as it does so. Full stop. No horn.
So what exactly does the horn accomplish that is not accomplished without it? That's a rhetorical question for you to answer.
I'd like to unrhetorical it: @Jimijel what exactly do you think the horn will do? And how do you think it relates to either the OceanGate or Byford dolphin tragedies?
Likes jack action
If we're talking about the issues of pressure on the human body, we run into physiological issues long before mechanical/physics issues. Decompression sickness, anyone?
Likes russ_watters
There are two distinct issued to discuss here.
Firstly, a deep submersible maintains surface pressure inside it and the passengers' bodies are not affected by the outside pressure. At any significant depth, the hull has to be immensely strong to withstand the ambient pressure.
Secondly, without the protection by a rigid hull, our bodies can only tolerate a very moderate pressure. 40m is the limit of water depth that recreational scuba divers can tolerate safely and, even at that depth, there are time limits and 'stops' during the ascent. Deeper, extended diving requires long periods of decompression - I have read one day of slow decompression time per 100m of dive depth - to allow the dissolved gasses to be breathed out safely.
FAQ: Decompressing through an underwater horn shaped tunnel
What is the purpose of decompressing through an underwater horn-shaped tunnel?
The purpose of decompressing through an underwater horn-shaped tunnel is to allow divers to safely transition from high-pressure environments to normal atmospheric pressure. This controlled decompression helps prevent decompression sickness, commonly known as "the bends," which can occur if the pressure is reduced too quickly.
How does the shape of the tunnel affect the decompression process?
The horn shape of the tunnel helps to gradually reduce the pressure as a diver ascends. The wider end of the horn allows for a more gradual and controlled expansion of gases within the diver's body, minimizing the risk of gas bubbles forming in the bloodstream, which is the primary cause of decompression sickness.
What materials are typically used to construct an underwater horn-shaped tunnel?
Underwater horn-shaped tunnels are usually constructed from strong, durable materials such as reinforced concrete, steel, or specialized composites. These materials need to withstand high pressures and corrosive underwater environments while ensuring the structural integrity of the tunnel.
Are there any specific protocols or procedures for using an underwater horn-shaped tunnel?
Yes, there are specific protocols that divers must follow when using an underwater horn-shaped tunnel. These include controlled ascent rates, monitoring of pressure changes, and adherence to decompression schedules. Divers may also need to undergo pre-dive medical assessments and use specialized equipment to ensure their safety during the decompression process.
What are the potential risks associated with decompressing through an underwater horn-shaped tunnel?
While decompression through an underwater horn-shaped tunnel is designed to minimize risks, potential dangers still exist. These include equipment failure, structural damage to the tunnel, and human error in following decompression protocols. Additionally, divers with pre-existing medical conditions may be at higher risk for complications during decompression.
