I Decorrelation steps in Wolff algorithm
  • I
  • Thread starter Thread starter IWantToLearn
    Simulation
In Monte Carlo simulations using the Wolff algorithm for the 2D/3D Ising and classical 3D Heisenberg models, a common guideline is to set decorrelation steps to 10 times the lattice size (10*L) to ensure independent measurements of observables, especially near critical temperatures. This recommendation aims to minimize autocorrelation in the data collected during simulations. However, the effectiveness of this rule can vary based on specific system parameters and conditions. Researchers are encouraged to validate the decorrelation step by monitoring the convergence of observables. Ultimately, ensuring adequate decorrelation is crucial for obtaining reliable simulation results.
IWantToLearn
TL;DR Summary
Hello all,
I am doing a monte Carlo simulation using Wolff algorithm for the 2D/3D Ising and classical 3D Heisenberg model, I have been told that the rule of thumb is to make your decorrelation steps = 10*L where L is the size of lattice, and this is would be sufficient enough to make independent measurements for observables even near the critical temperature
So what is recommendation really ?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
