Deduction of the action of this unitary on the wavefunction
In summary, the discussion involves operators satisfying ##[\hat{Z} , \hat{E}] = i \hbar##, with ##\hat{Z}## and ##\hat{E}## being Hermitian operators. The unitary operator ##U_\lambda = \exp (i \lambda \hat{Z} / \hbar)## is considered, and it has been proved that ##U_\lambda \hat{E} U_\lambda^\dagger = \hat{E} - \lambda##. This can be applied to any function of ##\hat{E}##, such as ##f (\hat{E})##, which may be Taylor expanded. The transformation can also be applied
julian
326
I have operators satisfying ##[\hat{Z} , \hat{E}] = i \hbar##. The operators ##\hat{Z}## and ##\hat{E}## are taken to be Hermitian. You consider the unitary operator
##U_\lambda = \exp (i \lambda \hat{Z} / \hbar)##.
I have proved that
##U_\lambda \hat{E} U_\lambda^\dagger = \hat{E} - \lambda \quad Eq.1##
I know how to apply Eq.1 to any function of ##\hat{E}##, ##f (\hat{E})##, which may be Taylor expanded. Moreover consider the application of the transformation to some matrix elements
##\int_0^\infty \psi^* (E) f (\hat{E}) \phi (E) dE = \int_0^\infty \psi^* U^\dagger U f (\hat{E}) U^\dagger U \phi dE = \int \psi^* U^\dagger f (\hat{E} - \lambda) U \phi dE##
I'm told that you can deduce from this that (and similarly for ##\psi^*##):
##U \phi (E) = \phi (E - \lambda)##.
I not sure I understand this. What am I missing?
Thanks.
The integration should run from ##-\infty## to ##\infty##. Then
$$\int_{-\infty}^\infty \psi^* (E) f (E) \phi (E) dE = \int_{-\infty}^\infty \psi^* (E-\lambda) f (\hat{E-\lambda}) \phi (E-\lambda) dE$$
Now compare this with ##\int_{-\infty}^\infty (U\psi)^\dagger f (E - \lambda) U \phi dE##
Actually ##E## is the Energy and is bounded from below, I've taken the lower bound to be ##E=0##, so that there are no energy-eigenstates for ##E < 0##. I probably should have mentioned that.
Did a major edit here.
Are you sure ##\hat{E}## is energy and should be bound to zero? What if ##E-\lambda## is negative, ##\phi(E-\lambda)## will then have no defined state?
Actually ##U## operator is called the translation operator, you may remember that there is a pair of well-known operators which satisfy the same commutator relation as our problem here, which are the momentum and position operators. Besides how come you explicitly write that the eigenvalues of ##\hat{E}## is continuous? Perhaps it will help if you tell us in which context/discussion you encountered this problem.
It is energy - I'm looking into the problems that arise when you attempt defining a putative Hermitian operator conjugate to the Hamiltonian operator (so a putative time operator. I'm aware that time is not a dynamical quantity but I'm ignoring that for the moment). In non-relativistic problems the energy has a lower bound and we may as well take it be 0 as we are allowed to.
By the way I'm not worrying too much about some of the mathematical subtleties right now - just trying to get a first handle on it.
The contradiction I'm leading up to is applying ##U## to an energy eigenstate, ##\phi (E) = \delta (E-E_0)##, which only has an amplitude at some particular energy ##E_0##, with ##\lambda## is sufficiently big to displace ##E_0## below ##E=0## where, by assumption, there are no energy eigenstates, proving no Hermitian ##\hat{Z}## exists.
In relativistic quantum mechanics there is the gap ##-mc^2 < E < mc^2##, so we can apply similar arguments there.
Come to think of it, my old prof's notes I'm looking at might have a mistake...when you do ##\phi(E) \mapsto \phi (E - \lambda)## what this does is moves the function to the right along the ##E-##axis by ##\lambda##.
If I want to shift the energy eigenstate ##\phi (E) = \delta (E-E_0)## to the left along the ##E-##axis (creating an energy-eigenstate with negative energy and hence a contradiction) don't I need to do ##\phi (E) \mapsto \phi (E+\lambda)##?
Obviously ##\phi (E+\lambda) = \delta (E+\lambda-E_0)## only has an amplitude at ##E = E_0 - \lambda##!
FAQ: Deduction of the action of this unitary on the wavefunction
What is a unitary operator?
A unitary operator is a mathematical operation that preserves the length of a vector, also known as a unit vector, in a vector space.
How does a unitary operator act on a wavefunction?
A unitary operator acts on a wavefunction by transforming it into a new wavefunction, while preserving its length and physical properties.
Why is it important to analyze the action of a unitary operator on a wavefunction?
Analyzing the action of a unitary operator on a wavefunction is important because it allows us to understand how the wavefunction evolves over time and how it is affected by different physical processes.
What is the significance of the deduction of the action of a unitary operator on a wavefunction?
The deduction of the action of a unitary operator on a wavefunction is significant because it enables us to make predictions about the behavior of a quantum system and to understand the underlying principles of quantum mechanics.
Can the action of a unitary operator on a wavefunction be experimentally verified?
Yes, the action of a unitary operator on a wavefunction can be experimentally verified through various quantum experiments and observations, providing evidence for the validity of quantum mechanics.
