Deep meaning of the work integral formula
In summary, the conversation revolves around the understanding and physical meaning of the work integral formula: \int m\frac{d\bar{v}}{dt}d\bar{l} The participants discuss the context of the formula, its relation to the work-energy theorem, and its usefulness in making quantitative predictions. The importance and special qualities of the quantity Fdl are also discussed, with an emphasis on its practical application in physics.
Aleoa
128
I want to understand very deeply the meaning of the work integral formula:
[tex] \int m\frac{d\bar{v}}{dt}d\bar{l} [/tex]
It is not enough for me to know that it was defined in this way, I want to know why it was defined in this way.
To start, what is the physical meaning of [itex]m\frac{d\bar{v}}{dt}d\bar{l}[/itex], what we are looking for when we calculate this term ?
Try to give us some context for your question. What aspect are you asking about? For example, are you familiar with the "work-energy" theorem and how it is derived? (See: Work–energy principle)
This is a strange form of the formula. The usual formula for work is: ##W=\int \vec F \cdot d \vec l##. They appear to only be equivalent if there is only a single force so ##F=F_{net}##
I also would appreciate some context. Where did you get this form and what are you looking to understand about it? “Deeply” is more of a description of the amount of understanding but not a description about what it is that you want to understand. What frustrates you about your current understanding?
My intuition is that in the integral formula of the work [itex]\int m\frac{d\bar{v}}{dt}d\bar{l} [/itex] the vectors dt and dl are linked, and that the integral simply represents the sum of all the mdv / dt along a path. Is this true ?
How dl and dt vectors are linked ?
Definitely not. ##\int y \; dx ## is the sum of all of the ## y\; dx ##, not the sum of all the ##y##.
It is customary to actually respond to the posts of the other participants, and not simply ignore them. It strongly discourages people from participating
So what is the fundamental quantity we are summing using the integral ? Doing some calculation I get the basic quantity we sum is mvdv, but physically what this quantity represents? It seems so an arbitrary quantity to me...
  • Sad
Likes Dale
To be useful in making quantitative predictions. Like everything in physics.
When we write [itex] \int m\frac{d\bar{v}}{dt}d\bar{l} [/itex] , what is the physical meaning of weighting the [itex]m\frac{d\bar{v}}{dt}[/itex] with the dl ?
It isn't a "weighting", it's a dot product.
The work done by a force is the component of the force in the direction of motion times the distance travelled. For an elementary displacement ##d\vec{l}##, that quantity is ##\vec F.d\vec l##. Then you integrate along the path to get the total work done.
This means that Fdl is a very important quantity, i suspect it's a conservative quantity. How can i analyze Fdl matematically (or physically) just to understand what means that it's a conservative quantity ?
The fact that the integral of Fdl has the name "work" say nothing to me, they could also have called it "X". What i want to understand is what is special about Fdl
It describes things we can observe to a good approximation and let's us make accurate. That is the basic requirement of any theory. Whether it has a ”deep” meaning or not is irrelevant.
Which is a tougher assignment:
Carry the box of copier paper from the ground floor up to the 2nd floor, or
Carry the box of copier paper from the ground floor up to the 3rd floor?
That is where my intuition on integrating F dot dS begins.
Leaving off the numerous caveats on human physiology vs simple physics.
Likes Dale
No. ##\vec F## may or may not be a conservative force. And energy is conserved, but that is not shown by this statement alone. So ##\vec F.d\vec l## is neither conserved (but the work must come from somewhere and the total energy is conserved) nor conservative (though ##\vec F## may be).
As Orodruin says, it's useful. That kind of post hoc justification is all there is in science, really.
The simplistic verbal definition of "work" for a constant force is "force times distance." This definition goes back to about 1600 and apparently arose in the analysis of simple machines such as levers. I descibed this a bit and gave a reference in the following post several years ago:
https://www.physicsforums.com/threads/what-is-up-with-work.584812/#post-3804085
It's post #9 in that thread, in case the link doesn't take you directly to it.
FAQ: Deep meaning of the work integral formula
1. What is the purpose of the integral formula?
The integral formula is used to calculate the area under a curve or the accumulation of a quantity over a given interval. It is a fundamental tool in calculus and is used to solve a variety of real-world problems in physics, engineering, economics, and more.
2. How is the integral formula related to derivatives?
The integral formula and derivatives are closely related as they are inverse operations of each other. The derivative calculates the rate of change of a function, while the integral calculates the total change or accumulation over a given interval.
3. What is the difference between definite and indefinite integrals?
A definite integral has specific limits of integration, meaning it calculates the area or accumulation over a specific interval. An indefinite integral has no limits of integration and represents the antiderivative of a function.
4. How is the integral formula used in real-world applications?
The integral formula is used in many real-world applications, such as calculating the volume of a three-dimensional shape, finding the distance traveled by an object with a changing velocity, and determining the total cost or profit of a business over a given time period.
5. What are some common techniques for solving integrals?
Some common techniques for solving integrals include substitution, integration by parts, trigonometric substitution, and partial fractions. These techniques help to simplify the integral and make it easier to solve using basic integration rules.
