Defendmyaname, astronomy questions ?
  • Thread starter defendmyname
  • Tags
    Astronomy
In summary, the conversation is about asking for the answers to several questions related to astronomy. The first question is about the reason why telescopes are used in space, with the correct answer being that the Earth's atmosphere absorbs or scatters some of the light at all wavelengths. The second question is about the type of telescope an astronomer would use to observe a receding galaxy with significant Doppler shifting, with the correct answer being the Hubble Space Telescope. The third question is about the chemical composition of the Sun 3 billion years ago, with the correct answer being that it had more hydrogen. The fourth question is about the blueshift and redshift of light from the Sun's east and west limb, with the correct answer being that the
defendmyname
Hello,
Can someone tell me which are the correct answers to these questions please ?
1.The reason astronomers use telescopes in space is because
a.absorbs all of the light at some wavelengths
b.absorbs or scatters some of the light at all wavelengths
c.distorts images of astronomical objects.
d.All of the Above
2. A galaxy can be moving away so quickly that its light is Doppler shifted significantly. What sort of telescope would an astronomer use to observe a receding galaxy that normally emits most of its light in the ultraviolet but is highly Doppler shifted?
a. Chandra X-ray Observatory
b. Hubble Space Telescope (UV and visible)
c. Infrared Space Observatory
d. Compton Gamma Ray Observatory
3. The chemical composition of the Sun 3 billion years ago was different from what it is now in that it had
a. molecular hydrogen.
b. more nitrogen.
c. more helium.
d. more hydrogen.
4.The light from the east limb (edge) of the Sun is blueshifted and the light from the west limb is redshifted. This is because
a. the Sun is rotating.
b. the two sides of the Sun are at different temperatures.
c. different kinds of atoms emit light at the opposite edges.
d. the distance from the Sun to the Earth changes.
5. The Sun's layer just outside the core is the
a.photosphere.
b. radiation zone.
c. chromosphere.
d. convection zone.
6.The corona of the Sun can only be seen naturally on Earth under what circumstances?
a. During an annular eclipse.
b. Anytime
c. During a partial solar eclipse
d. During a total eclipse.
Thank you in advance,
Defendmyname.
We do not just give out answers to homework here. You have to show that you have tried to do it yourself.
1. The correct answer is b. Absorbs or scatters some of the light at all wavelengths. This is because the Earth's atmosphere does not completely absorb all light, but it does scatter and absorb some of it which can distort images of astronomical objects.
2. The correct answer is c. Infrared Space Observatory. This is because the galaxy is highly Doppler shifted, meaning its light is shifted towards longer wavelengths, and the Infrared Space Observatory is designed to observe light in the infrared range.
3. The correct answer is d. More hydrogen. This is because the Sun's chemical composition has changed over time, with more hydrogen being present 3 billion years ago compared to now.
4. The correct answer is a. The Sun is rotating. This is because the Sun's rotation causes the Doppler effect, which results in the blue and redshift of light from different sides of the Sun.
5. The correct answer is d. Convection zone. This is the layer just outside the core where energy is transported through the movement of hot gases.
6. The correct answer is d. During a total eclipse. This is because during a total eclipse, the Moon completely blocks out the bright light from the Sun's photosphere, allowing the fainter corona to be seen.
Related to Defendmyaname, astronomy questions ?
1. What is the origin of the name "Defendmyaname"?
The name "Defendmyaname" is a user-generated username and does not have a specific origin or meaning in astronomy.
2. What is the closest known exoplanet to Earth?
The closest known exoplanet to Earth is Proxima Centauri b, which orbits the red dwarf star Proxima Centauri and is approximately 4.2 light years away from Earth.
3. How do astronomers measure the distance to stars?
Astronomers use a variety of methods to measure the distance to stars, including the parallax method, which measures the slight shift in a star's position as the Earth orbits the sun, and the standard candle method, which uses the known brightness of certain stars to determine their distance.
4. What is a black hole?
A black hole is a region in space with such a strong gravitational pull that nothing, not even light, can escape from it. They are formed when a massive star dies and its core collapses under its own gravity.
5. How do astronomers study the composition of stars?
Astronomers study the composition of stars by analyzing the light they emit. Each element in a star's atmosphere absorbs and emits specific wavelengths of light, which can be detected and used to identify the elements present.
  • Quantum Interpretations and Foundations
  • Science and Math Textbooks
  • Astronomy and Astrophysics
