MHB Define a discontinuous sine function?
  • Thread starter Thread starter samir
    Function Sine
A discontinuous sine function can be defined to be undefined at multiples of π while retaining continuity elsewhere. The proposed function needs to ensure that it assigns a value different from zero at these discontinuous points to meet the mathematical definition of discontinuity. A suggested correction is to define the function as f(x) = sin(x) for x not equal to πn, and assign a specific value (not zero) for x equal to πn. Additionally, the conditions in the function definition must be mutually exclusive to avoid ambiguity. Clear and precise notation is essential for accurate mathematical representation.
samir
Hi!
I want to define a sine function that is discontinuous at multiples of $\pi$. The multiplier is to be an integer.
How can I do that?
I am thinking about something like this:
$$f(x)=\begin{cases}sin(x) & x \in \Bbb{R} \\ \text{undefined} & x=n \cdot \pi | n \in \Bbb{Z} \text{ and } x \in \Bbb{R}\end{cases}$$
Is this a valid statement?
Not only does it need to be discontinuous, but also undefined at these multiples. I believe it is the only way to have such a function be discontinuous at those multiples. Let me know if you know of another way.
I tried to graph this on my calculator but it didn't work. I think I need to define the condition for undefined in terms of x. Can I do that?
It seems like my calculator wants me to define $n$ first before I use it. But how do you define a variable that holds an element of the infinite set of integers? I'm not so sure. If I could set the data type to integers, that would get me half way there. Since it is a programmable calculator it should be possible. This is more of a product usage question, so I will leave that off for now. What I really want to know is if my definition of such function above is mathematically correct? I can deal with the calculator and graphing later.
Mathematics news on Phys.org
A function can only be continuous or discontinuous at points where it is defined, because the definition of continuity/discontinuity involves the value of the function at that point. So your function need to be defined at multiples of $\pi$, but its value there should be different from the value of the sine function at those points (which is $0$). So you should amend your definition to say that $f(x) = \sin x$ when $x$ is not a multiple of $\pi$, and $f(x) = 1$ (say, or $17.629$, or anything at all other than $0$), when $x$ is a multiple of $\pi$.
I would write
f(x)=\begin{cases}\sin(x), & x \ne\pi n\text{ for any }n\in\mathbb{Z}\\ \text{undefined}, & \text{otherwise}\end{cases}
The conditions in the two branches should be mutually exclusive. The conditions $x\in\Bbb R$ and $x=\pi n$ for some $n\in \Bbb Z$ are not mutually exclusive. Further, the vertical bar is only used in the set-builder notation, e.g., $\{x\in\Bbb R\mid x>0\}$ (and in this case it is written using the LaTeX command [m]\mid[/m] to create correct spacing on both sides). It does not have a universally accepted meaning of "such that" in other contexts. Finally, it is superfluous to write $x=n \cdot \pi | n \in \Bbb{Z} \text{ and } x \in \Bbb{R}$ because $x=\pi n$ and $n\in\Bbb Z$ imply $x\in\Bbb R$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
