Define inner product of vector fields EM
In summary, the conversation was about the definition of inner product for two vector fields, and how if one of the fields is a harmonic mode of an electromagnetic system, the inner product can always be set to 1. This was demonstrated by setting the field to a scalar multiple of itself and showing that it is the same solution. By substituting in this value, it can be easily verified that the inner product is indeed 1.
Kara386
208
I'm reading a textbook on electromagnetism. It says that for two vector fields ##\textbf{F}(\textbf{r})##
and ##\textbf{G}(\textbf{r})## their inner product is defined as
##(\textbf{F},\textbf{G}) = \int \textbf{F}^{*}\cdot \textbf{G} \thinspace d^3\textbf{r}##
And that if ##\textbf{F}## is a harmonic mode of an electromagnetic system we can always set ##(\textbf{F},\textbf{F})=1##. To demonstrate this they set
##\textbf{F} = \frac{\textbf{F}'}{\sqrt{(\textbf{F}',\textbf{F}')}}##
Then say this is a scalar multiple of ##\textbf{F}##, so it's really the same solution (which is because you can add two solutions, multiplied by a constant, together to get another solution). Setting ##\textbf{F}## to have this value allows the reader to easily verify that we can always set this inner product to be one. How does it let me easily verify that? That dot product has to be zero for the inner product to be 1, doesn't it?
Just substituting in works fine, sorry! Made a mistake!
FAQ: Define inner product of vector fields EM
What is an inner product of vector fields in electromagnetic theory?
An inner product of vector fields in electromagnetic theory is a mathematical operation that takes two vector fields as input and produces a scalar value as output. It is used to measure the similarity or "closeness" between two vector fields, and is an important tool in understanding the behavior of electromagnetic fields.
How is the inner product of vector fields calculated in electromagnetic theory?
The inner product of vector fields in electromagnetic theory is calculated using the dot product formula: A · B = |A||B|cosθ, where A and B are the two vector fields and θ is the angle between them. This formula takes into account both the magnitude and direction of the vector fields, and produces a scalar value as the result.
What is the significance of the inner product in electromagnetic theory?
The inner product of vector fields is significant in electromagnetic theory because it allows us to quantify the relationship between two vector fields. It is used to determine the strength and direction of electric and magnetic fields, and is an essential tool in analyzing electromagnetic phenomena such as induction and radiation.
How does the inner product of vector fields relate to Maxwell's equations?
The inner product of vector fields plays a crucial role in Maxwell's equations, which are a set of fundamental equations that describe the behavior of electric and magnetic fields. In these equations, the inner product is used to calculate the divergence and curl of vector fields, which are essential in understanding the behavior of electromagnetic fields.
Can the inner product of vector fields be applied to other fields besides electromagnetism?
Yes, the inner product of vector fields is a general mathematical concept and can be applied to any vector fields, not just those in electromagnetism. It is commonly used in physics, engineering, and mathematics to measure the similarity between two vector fields and has applications in various fields such as fluid mechanics, quantum mechanics, and computer graphics.
