Define Vector on x-Axis: -d/2 to d/2
  • B
  • Thread starter Philosophaie
  • Tags
    Vector
In summary, to define a vector starting on the x-Axis at -d/2 ending at d/2 on the x-Axis, you can use the notation ##(d)## or the pair notation ##(p;\vec{v})## with ##p=-\frac{d}{2}## and ##\vec{v}=d##.
Philosophaie
462
How do I define a vector starting on the x-Axis at -d/2 ending at d/2 on the x-Axis?
You define it as ##(d)##.
A vector notation doesn't say anything about where it is applied at. It simply has a length - here ##d## - and a direction - here only in one coordinate, so ##(*)\,##. If you want to describe a vector as its point of application and its length and direction, then you need to use pairs ##(p;\vec{v})##. Here it would be ##(p;\vec{v})=(-\frac{d}{2};d)##.
FAQ: Define Vector on x-Axis: -d/2 to d/2
What is a vector on the x-axis?
A vector on the x-axis is a mathematical concept that represents a quantity with both magnitude and direction along the x-axis. It is typically denoted by a boldface letter or an arrow above the variable.
What is the range of a vector on the x-axis?
The range of a vector on the x-axis is from -d/2 to d/2, where d is the total distance covered by the vector. This means that the vector can have a magnitude of up to d/2 in either the positive or negative direction on the x-axis.
How is a vector on the x-axis represented graphically?
A vector on the x-axis is represented graphically by a line segment with an arrow pointing in the direction of its magnitude. The length of the line segment represents the magnitude of the vector, while the direction of the arrow represents the direction of the vector along the x-axis.
What are some examples of vectors on the x-axis?
Examples of vectors on the x-axis include displacement, velocity, and acceleration in one-dimensional motion. These quantities have both magnitude and direction along the x-axis, making them vector quantities.
How is a vector on the x-axis different from a scalar?
A vector on the x-axis is different from a scalar in that a scalar only has magnitude, while a vector has both magnitude and direction. Scalars are represented by regular letters, while vectors are represented by boldface letters or arrows above the variable.
