B Defining an operation such that ##1+2+3=123##
  • B
  • Thread starter Thread starter Saracen Rue
The discussion revolves around defining an operation that concatenates numbers instead of adding them, exemplified by the equation 12 + 34 = 1234. This operation, known as concatenation, is commonly used in programming languages for strings, though there is no universally recognized symbol for it outside of programming. The conversation suggests using the plus sign '+' for concatenation, while emphasizing the need to distinguish it from numerical addition, potentially by using quotes around numbers. Additionally, a proposed notation for this operation is discussed, highlighting its associative but non-commutative nature. The topic also touches on how different programming languages handle concatenation, with Python providing multiple methods for achieving it.
Saracen Rue
Firstly, I'm aware that title doesn't really make sense but stick with me on this. I'm trying to find a way to define an operation which will "join" two numbers instead of adding them. So for example, ##12+34=1234##. Ideally, it would be great if it also had something similar to sigma notation, like so:
$$\sum_{k=1}^{n} k= 12345...n$$
I'm sure this is actually something trivial that has been defined before, but I was finding it really difficult to search it up on Google (apparently "addition but instead of adding numbers just clomp together" doesn't yield very good results). So yeah, if anyone can tell me a better way to name this sort of maths it'd be greatly appreciated.
Mathematics news on Phys.org
This is called concatenation. You often have to program this kind of operation for strings or text.
Likes berkeman, fresh_42, jedishrfu and 2 others
In computer languages, this is often done but there is no standardized symbol that would be universally recognized in other fields. Since C++ is such a well-established language, it might be the best thing to mimic. It uses the plus '+' symbol. The trick would be to distinguish it from numerical addition. Consider using quotes to make it clear that you are treating the number as a text string: "12"+"34"="1234".
If this is to appear in a document, you should clearly define your notation and symbology in the document.
I suppose you have \oplus : \mathbb{N}^2 \to \mathbb{N} : (a,b) \mapsto \begin{cases} 10^{1 + \lfloor\log_{10}(b)\rfloor}a + b, &amp; b \neq 0, \\ 10a, &amp; b = 0\end{cases} which (if it does what I think it does) is associative but not commutative, and you need to decide whether <br /> \bigoplus_{n=0}^N a_n means a_0 \oplus a_1 \oplus \cdots \oplus a_N or a_N \oplus a_{N-1} \oplus \cdots \oplus a_0.
Likes malawi_glenn and PeroK
In some computer languages, the addition operator took on different meaning dependent on the datatypes of items being added. It acted as normal addition for numeric types and as a concatenation operator for string types.
There were some purists who complained that since concatentation is not commutative that the addition operator shouldn't serve that function. However, using the addition operator for concatenation had become a defacto standard and was here to stay.
In Python, one can concat in several different ways:
- string1 + string2
- " ".join(string1, string2)
https://www.geeksforgeeks.org/python-string-concatenation/
and here's a larger set of multi language string concatentation examples:
https://en.wikipedia.org/wiki/Comparison_of_programming_languages_(string_functions)#Concatenation
Likes berkeman, PeroK and FactChecker
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
