Defining Branch Cuts for f(z) = z^(1/3)
In summary: Not sure what you mean. Do you know what a cut is? It appears on *the complex plane* NOT on the Riemann surface. The sheets are just copies of $\Bbb C$ along which they are cut and identified properly.
Dustinsfl
2,281
Given the function \(f(z) = z^{1/3}\). Can the branch cuts be defined by the rays from zero through the three roots of unity and to infinity?
Branch cuts are curves on $\hat{\Bbb C} = \Bbb C \cup \{\infty\}$ removal of which gives a domain $D \subset \hat{\Bbb C}$ over which $f(z)$ is holomorphic.
The sheets of $f(z) = z^{1/3}$ are branched only at $z = 0$ in the complex plane. Why the three roots of unities? The only branches of $z^{1/3}$ on $\Bbb P^1$ are $z = 0$ and $z = \infty$ so take any closed curve $\Gamma$ joining those points on the Riemann sphere.
There should be three branch cuts though from 0 out to infinity. Is it not common to define it through the rays that would connect to the roots of unity?
Why the roots of unities? Branch cuts are usually taken through *branch points* of $z^{1/3}$. What are the branch points of $w = z^{1/3}$ over $\hat{\Bbb C}$?
Are you implying that you want to draw three branch cuts from $0$ to $\infty$, $\omega \infty$ and $\omega^2 \infty$ respectively? Please clarify.
That is what I said in the first post.
It's unnecessary in that case. $\infty, \omega \infty, \omega^2 \infty$ all identifies to the point at infinity in the Riemann sphere $\Bbb P^1$. A single slit through $0$ to $\infty$ is sufficient.
What are the other two branch cuts then? Functions of the form \(z^{m/k}\) where \(gcd(m,k) = 1\) have \(k\) branch cuts. If you are saying the other two branch cuts are the same, where are the other two at then?
Where did you find that? It's false : $z^{1/n}$ has a single branch cut from $0$ to $-\infty$.
Perhaps whatever text included that meant that there must be $n$ branch cuts on *each* sheet (# of sheets are $n$) of the Riemann surface?
The branch cuts don't occur where the sheets of Riemann surface are split then?
FAQ: Defining Branch Cuts for f(z) = z^(1/3)
What is a branch cut?
A branch cut is a mathematical concept used to define a multivalued function. It is a curve or line on the complex plane where a function is discontinuous, meaning it has a jump or gap in its values. Branch cuts are used to limit the range of values a function can take on.
How are branch cuts used in mathematics?
Branch cuts are used to define principles such as the complex logarithm and complex power functions, which have multiple values. They are also used in calculus to define integrals and in differential equations to solve problems with multiple solutions.
What is the purpose of a branch cut?
The purpose of a branch cut is to define a single-valued function from a multivalued function. It allows for the selection of a specific branch or range of values for a function, making it easier to work with and analyze mathematically.
How are branch cuts determined?
Branch cuts are determined by analyzing the behavior of a function on the complex plane. They are often chosen to be along the negative real axis, but can also be chosen based on the specific properties and behavior of the function being defined.
Can a function have more than one branch cut?
Yes, a function can have multiple branch cuts. The number and location of branch cuts are dependent on the specific function being defined and its properties. It is possible for a function to have no branch cuts, but this is less common.
