Defining electromagnetic waves
In summary: The stone provides the energy/momentum that sets the waves in motion. The water itself does the waving.But, this analogy is not perfect because water waves are also disturbances travelling through a substance (water) whereas EM waves are disturbances that are part of the structure of the vacuum itself.In summary, electromagnetic waves are produced by the oscillation of electric and magnetic fields, not by accelerated electrons. Electrons are sources of the EM field, not the EM field itself. In the quantum theory of light, photons are the quanta of the EM field, while electrons are the quanta of the electron field, and particles in general are the quanta of the appropriate field. While EM and QED produce similar results
Andreea007
TL;DR Summary
Which ones describe electromagnetic waves? Photons or electrons?
Hi! So I'm trying to understand electromagnetic waves but I encountered different definitions: one in terms of electrons and one in terms of photons. Which ones are actually used to produce electromagnetic waves and how?
Also, I saw that alternating current generates electro magnetic waves, but ac is all about accelerated electrons, so how is it possible?
Thank you!
Visible light/which is photons/ is an electromagnetic field. In QFT the electron field is what produces electrons. Different situations.
Can you be a little more specific? What do you mean by electron field? Isn't it the same as electromagnetic field?
Andreea007 said:
Summary:: Which ones describe electromagnetic waves? Photons or electrons?
Thank you!
Electromagnetic waves and electromagnetic fields in general are part of classical electromagnetism (EM), governed by Maxwell's equations. The electron is a fundamental charged particle that creates an EM field; and, an accelerated electron produces electromagnetic radiation. There are no photons in classical EM.
The photon is a massless particle in Quantum Electrodynamics (QED), which is a quantum theory of light. The electron remains a fundamental charged particle.
Although EM and QED produce approximately the same results in many cases, in terms of high-energy particle interactions, EM tends to break down and QED is seen to be the more accurate theory.
Many people talk loosely of EM radiation "being made of photons", but this is either sloppy or simply wrong depending on yout point of view.
Likes vanhees71 and Dale
In QFT (Quantum Field Theory), there is a quantised EM field (which is a quantum mechanical upgrade to the classical EM field) and an electron field (which has no analogue in classical EM). Photons are the quanta of the EM field and electrons are the quanta of the electron field - and, indeed, particles in QFT generally are the quanta of the appropriate field.
I have a question for you. If the electromagnetic waves are made up of accelerated electrons, then what about the vacuum? I mean, the light travels through space, right? Electrons are not massless particles, but there is no mass in the vacuum because there is no substance, so there are no electrons. How do you explain that?
It would help if you could link to these two specific definitions that are confusing you. That way we can see if they are genuinely conflicting or not.
An EM wave is just a specific configuration of the EM fields, specifically one in which the fields are oscillating in a wave pattern and energy is being transported. Electrons are sources of the EM field. They are not the EM field itself any more than your faucet (a source of water) is water itself.
I'm not sure where you got that idea from. An electromagnetic wave is the propagation of alternating electric and magentic fields - and is also known as light.
An electron at rest produces a simple electric field. But, an accelerated electron produces an EM wave:
http://labman.phys.utk.edu/phys222core/modules/m6/production_of_em_waves.html
PS note that this is classical EM, not quantum physics.
Perhaps a stone dropped into a pool that creates water waves would also be a good analogy. The water waves are not made of stones, but are oscillations in the surface of the water.
Likes Dale
Yeah I still don't get it. I'm asking you again, how do electromagnetic waves travel through vacuum (void) ? Are there any electrons in the void? Because, if they exists then it means particles exists, and for all we know void is void.
  • Skeptical
Likes PeroK
The EM field occupies the vacuum. And, therefore, technically it isn't vaccum, but space with EM radiation.
Electrical and magnetic fields pass through a vacuum just fine. Put a charged particle in a vacuum chamber and its electrical field will affect other particles even though it's in a vacuum.
Likes PeroK
Where did you encounter these definitions? Please give specific references.
They aren't. Accelerated electrons produce electromagnetic waves, but that doesn't mean the electromagnetic waves themselves are made of accelerated electrons. They aren't.
It's simply wrong, particularly if you imply that a photon is just a massless "particle", as if it were in any sense localizable as a small lump of matter. It is almost always better to think in terms of waves when thinking about light.
FAQ: Defining electromagnetic waves
What are electromagnetic waves?
Electromagnetic waves are a type of energy that is created by the movement of electrically charged particles. They are composed of oscillating electric and magnetic fields that travel through space at the speed of light.
How are electromagnetic waves created?
Electromagnetic waves are created when an electrically charged particle, such as an electron, is accelerated or decelerated. This creates a disturbance in the electric and magnetic fields, which then propagate as a wave.
What is the electromagnetic spectrum?
The electromagnetic spectrum is the range of all possible frequencies of electromagnetic radiation. It includes all types of electromagnetic waves, from the low-frequency radio waves to the high-frequency gamma rays.
What are the properties of electromagnetic waves?
Electromagnetic waves have several properties, including wavelength, frequency, amplitude, and speed. They also do not require a medium to travel through and can travel through a vacuum.
What are some practical applications of electromagnetic waves?
Electromagnetic waves have numerous practical applications, including communication technologies like radio, television, and cell phones. They are also used in medical imaging, cooking, and remote sensing for weather forecasting and mapping.
