Defining proper distance in GR.
In summary, the author defines the proper time element and spatial proper distance in Landau and Lifshitz' Classical Theory of Fields through the line element and notes that in special relativity, the spatial distance can be defined as the distance between two events with the same coordinate time. However, in general relativity, this is not possible due to the different dependence on coordinate time in a gravitational field. Instead, the author defines the spatial proper distance by sending and reflecting back a light ray from/to a stationary observer. This method takes into account the unique geodesic connecting the two events and provides a more accurate measurement of distance.
center o bass
560
At page 234 in Landau and Lifshitz' Classical Theory of Fields the proper time element is defined through the line element by ##ds^2 = c^2 d\tau^2##, then for a stationary observer, setting ##dx^i=0## for ##i=1,2,3##. One then obtains the relation
$$c^2 d\tau^2 = g_{00}(dx^{0})^2.$$
He then goes on to define the spatial proper distance ##dl^2## and notes that in SR ##dl^2## can be defined as the spatial distance between two events infinitesimally separated, but with the same coordinate time, i.e. by setting ##dx^0 = 0## in the line-element. He claims that this is not possible in GR because the proper time in a gravitational field may have a different dependence on ##x^0## at different points in space.
He then goes on to define ##dl^2## by sending and reflecting back a light ray from/to a stationary observer.
I remember naively doing exactly this when I started learning about GR, but getting the wrong answer. I never really understood why it was not allowed and I'm not sure if I understand what the author is saying here, so I wondered if someone could elaborate on why we can not define the proper distance in this way as one did in SR.
PS: I know it's become common to completely ignore the notion of a line-element and just work
with tensors, i.e. the metric tensor. But I would like to understand it in both ways.
You can define a distance with the line element. If you have two events with spacelike separation that you consider to be simultaneous, you can define the proper distance between them as the integrated line element (with the right sign) along them for the geodesic connecting them. If they are 'near by', this will be unique. In general, in GR, it will not always be unique - there can be multiple geodesics. You can adopt a convention of smallest length.
However, the real issue becomes relating this to measurements. What you typically have in physical scenario is two world lines. So to execute the above, you have to decide which pairs of events on the world lines you consider simultaneous. Radar distance solves this by jointly providing a simultaneity choice and distance measurement that can be readily carried out of substantial distances, by one of the world lines.
For reasonably nearby world lines, a 'ruler distance' is typically defined, and presumed to predict the result of using a reasonable implementation of a ruler. The definition is to find a spacelike geodesic 4-orthogonal to the tangent of one of the world lines at some event that intersects the other world line. Then, the proper length of this geodesic segment is the ruler distance between them per the first world line at the chosen time along the first world line.
The author seems to be defining distance and spatial geometry by what you call "radar distance". He then obtains that
$$dl^2 = (g_{ij} - \frac{g_{0i}g_{0j}}{g_{00}}) dx^i dx^j \equiv \gamma_{ij}dx^i dx^j$$
where he calls ##\gamma_{ij}## the spatial metric. I guess my question is what is wrong with the following argument?:
The spacetime interval between two infinitesimally close events are
$$ds^2 = g_{00}(dx^0)^2 + 2g_{i0}dx^0 dx^i + g_{ij} dx^i dx^j$$
and for a stationary observer (##dx^0 = 0##), ##ds^2 = dl^2## so that
$$dl^2 = 2g_{i0}dx^0 dx^i + g_{ij} dx^i dx^j.$$
The problem is that what you propose is physically meaningless. A line of constant coordinate time would typically have no meaning for an observer following world line of constant coordinate position. Thus, the only physically plausible alternative to radar distance that I know of is the ruler distance definition I gave.
I think I agree; it would only make sense if the worldline was parametrized by ##x^0##. But then on the other hand does it make sense to set ##dx^i = 0## to find a relation between the proper-time interval and ##dx^0## like Landau did?
Can you check out the derivation of the proper length in Landau's book? You can find it here
http://archive.org/details/TheClassicalTheoryOfFields
at page 234. If so would you say that the derivation is sensible?
No, it would only make sense if the line of constant coordinate time was a geodesic, and it was 4-orthogonal to the world line of constant coordinate position. Neither of these is likely to be true.
Proper time is different because it gives the time read by a clock following the constant coordinate position world line, always. No assumptions or restriction, as long as it is actually a world line (timelike path).
His derivation looks fine to me. He is only defining it for an 'infinitesimal' distance, in which case it is not hard to show that there is no difference between radar and ruler distance. He describes the issues I allude to for integrating it, but makes no suggestion other than for case of a static metric.
If the worldline of an observer is (affinely) parametrized by ##x^0##, then ##x^0## is proportional to that observers proper time. Setting ##dx^0 = 0## would then be equivalent with setting the proper-time interval to zero, which is physically meaningfull. Why would it have to be a geodesic and four orthogonal to constant coordinate worldlines?
I thought it was just the time read by a clock following a worldline in general. Why does it have to be a constant position-coordinate world line? Can not the observer use coordinates for which the "spatial coordinates" need not be constant along the world line? Wouldn't that correspond to a coordinate system with a coordinate basis for which ##\vec{e_0} \cdot \vec{e_i} \neq 0## which is allowed?
Yes this is true. And in the comoving coordinates associated with the observer described by the worldline (in which the observer is of course at constant spatial coordinates-naturally the origin of the comoving coordinates), the proper time read by said clock is just the coordinate time of said coordinates, by construction.
It would have to be a geodesic if you wanted to integrate along it - else it would have no meaning as a distance. If you are looking only at infinitesimals, all you need is 4-orthogonal. That says it s consistent with local Lorentz simultaneity. In general coordinates in GR a spatial coordinate will not be 4-orthogonal to the time coordinate at some point. You can tell easily: if the metric at that point has no off diagonal elements, then you meet the locally orthogonal condition.
I was answering as to why don't have to worry about anything except g00 to talk about the rate of proper time along the time coordinate, while for distance you have to worry about othogonality, even for infinitesimals.
But exactly what in the argument is wrong and why?; If the worldline of an observer is parametrized by ##x^0## then for that observer, ##dx^0 = 0## is equivalent with ##d\tau = 0## regardless of whether the spatial coordinates are time-orthogonal or not. Thus the spacetime interval between two infinitesimaly separated events which for the observer in question happens at the same proper time is
$$ ds^2 = g_{00} \times 0^2 + 2 g_{i0} dx^i \times 0 + g_{ij}dx^i dx^j$$
and this we call proper length.. But it's not.
The issue is proper length for who? At least infinitesimally, the formula you give will be proper length for 'someone' but not, in general, for the observer who follows a line of constant coordinate position. For this observer, their local simultaneity will have to be 4-orthogonal to the world line of constant coordinate position. This will not be a line of constant time coordinate unless the metric at that point has no off diagonal elements.
To add on to PAllen, let's say we have an observer with 4-velocity ##\xi^{\mu}## then at any event ##p## on the observer's worldline, there exists locally a space-like hypersurface which is orthogonal to ##\xi^{\mu}## at ##p##. Operationally, it is constructed by sending out space-like geodesics in every direction emanating from ##p## that are orthogonal to ##\xi^{\mu}## at ##p##; the images of these geodesics, when restricted to a sufficiently small open subset, will sweep out a space-like hypersurface orthogonal to ##\xi^{\mu}## at ##p##. This defines the local simultaneity slice at ##p## relative to this observer (all we're doing is using the exponential map). Now if you were in the coordinates comoving with the observer then a surface of constant ##x^0## need not correspond to such a local simultaneity slice if the representation ##g_{\mu\nu}## of the metric tensor in the comoving coordinates has terms ##g_{0i}## because then the surfaces of constant ##x^0## are not orthogonal to ##\xi^{\mu}## and do not translate over to a local simultaneity slice.
Take for example the observers at rest in the Kerr chart on Kerr space-time; this chart by itself defines comoving coordinates for these static observers following orbits of the time-like killing field ##\xi^{\mu} = (\partial_{t})^{\mu}##. However ##\xi^{\mu}## is not orthogonal to the surfaces of constant ##t##; the surfaces of constant ##t## do not represent local simultaneity slices for these observers. They are however orthogonal to the vector field ##\nabla^{\mu}t## but the observers following orbits of ##\nabla^{\mu}t## are not at rest in the Kerr chart (they will be orbiting the central body).
Related to Defining proper distance in GR.
1. What is the proper distance in General Relativity (GR)?
The proper distance in GR is the distance between two points in space-time that is measured by an observer who is at rest relative to those two points. It takes into account the curvature of space-time, which is a fundamental concept in GR.
2. How is proper distance different from Euclidean distance?
Proper distance takes into account the curvature of space-time, whereas Euclidean distance assumes that space-time is flat. This means that proper distance can be longer or shorter than the Euclidean distance, depending on the curvature of space-time.
3. Can proper distance be negative?
Yes, proper distance can be negative in certain cases. This occurs when the two points are moving away from each other faster than the speed of light, which is allowed in GR due to the curvature of space-time.
4. How is proper distance related to the expansion of the universe?
The proper distance between two galaxies in an expanding universe is constantly increasing due to the expansion of space itself. This means that the proper distance between two galaxies that are far apart will be larger than the proper distance between two galaxies that are closer together.
5. What is the significance of proper distance in GR?
The concept of proper distance is essential in understanding the behavior of objects in a universe where space-time is not flat but curved by the presence of mass and energy. It allows us to accurately measure distances in a universe where the traditional Euclidean geometry does not apply.
