Definite integral as Riemann sums
The discussion focuses on calculating the definite integral of ##\int_{0}^{2}\sqrt{x}dx## using left Riemann sums. Participants clarify the formula for Riemann sums and point out issues with the infinite series involved in the calculation. There is confusion regarding the summation of square roots and whether the series can be summed exactly or approximated. Suggestions are made to simplify the approach by observing the behavior of the sums rather than attempting to compute them directly. The conversation emphasizes the complexity of the problem and the challenges in finding an exact solution.
terryds
Determine ##\int_{0}^{2}\sqrt{x}dx## using left riemann sums
##\int_{a}^{b}f(x)dx = \lim_{n\rightarrow \infty}\sum_{i=0}^{n-1}(\frac{b-a}{n})f(x_i)##
[/B]
##\frac{b-a}{n}=\frac{2-0}{n}=\frac{2}{n}##
##\int_{0}^{2}\sqrt{x}dx = \lim_{n\rightarrow \infty}\frac{2}{n}(0+ \frac{\sqrt{2}}{n}+\frac{\sqrt{4}}{n}+...) =\lim_{n\rightarrow \infty}\frac{2}{n} \frac{\sqrt{2}}{n}(\sqrt{0} + \sqrt{1}+\sqrt{2}+\sqrt{3}+...) ##
I'm stuck now. Please help. I don't know how to get the sums of the infinite radical series
[/B]
##\int_{0}^{2}\sqrt{x}dx = \lim_{n\rightarrow \infty}\frac{2}{n}(0+ \frac{\sqrt{2}}{n}+\frac{\sqrt{4}}{n}+...) =\lim_{n\rightarrow \infty}\frac{2}{n} \frac{\sqrt{2}}{\color{red}n}(\sqrt{0} + \sqrt{1}+\sqrt{2}+\sqrt{3}+...) ##
I think you may want a square root on that ##n## I colored red. But to answer your question, that is not a trivial sum to calculate, and I wouldn't expect to see this problem in a typical calculus exercise set. See, for example,
http://math.stackexchange.com/questions/1241864/sum-of-square-roots-formula
Likes terryds
[/B]
The sums in the last two expressions above do not have an infinite number of terms. What's the last term in each sum?
Likes terryds
##\lim_{n\rightarrow \infty }\frac{2}{n}\sqrt{\frac{2}{n}}(\sqrt{0} + \sqrt{1} + \sqrt{2} + ... + \sqrt{\frac{2}{n}}(n-1)))##
Alright, I've fixed my mistakes. And, I'm still confused how to get the sum of that series
You should go back and read post #2, which explains why you probably cannot sum the series, no matter how hard you try. Of course, you may be able to find good approximations to the sum, but that is not the same as finding an exact value.
Likes terryds
Doing the sum is overkill for finding the limit.
I think you have an error I think you should have
$$\int_0^2 \! \sqrt{n} \, \mathrm{d}x=\lim_{n\rightarrow\infty} {\left( \frac{n}{2} \right)}^{-3/2}\sum_{i=1}^n \sqrt{n}$$
Instead of finding the sum we will make a few observations that suffice
we can replace the sum in the limit by a simple expression
$$\sum_{i=1}^n \sqrt{n}\sim {C} {\sqrt{n}}^3$$
The exponent is the only one that allows the limit to converge to a nonzero value
we find C by computing the limit
$$C=\lim_{n\rightarrow\infty}\frac{{\sqrt{n}}}{{\sqrt{n+1}}^3-{\sqrt{n}}^3}$$
because we must have
$$\sum_{i=1}^{n+1} \sqrt{n}-\sum_{i=1}^n \sqrt{n}\sim {\sqrt{n}}$$
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
