Definite Integral challenge #3
In summary, the conversation was about evaluating the following integral: $$\int_0^{\pi} e^{\cos x} \cos(\sin x)\,\,dx$$ A participant pointed out that the question was missing $dx$, which was then corrected. Another participant mentioned an alternative way to solve the problem without using the "res" function.
Saitama
4,243
93
Evaluate the following:
Mathematics news on Phys.org
$$\int_0^{\pi} e^{\cos x} \cos(\sin x)$$
Are you sure of the question because you are missing $dx$ ?
Haha, nice catch! Edited. :eek:
$$\int_{0}^{\pi} e^{\cos x} \cos(\sin x) \ dx = \frac{1}{2} \text{Re} \int_{-\pi}^{\pi} e^{e^{iz}} \ dz = \frac{1}{2} \text{Re} \frac{1}{i} \int_{|z|=1} \frac{e^{z}}{z} \ dz $$
$$ = \frac{1}{2} \text{Re} \frac{1}{i} 2 \pi i \ \text{Res} \left[ \frac{e^{z}}{z},0 \right] = \text{Re} \ \pi (1) = \pi $$
$$ = \frac{1}{2} \text{Re} \frac{1}{i} 2 \pi i \ \text{Res} \left[ \frac{e^{z}}{z},0 \right] = \text{Re} \frac{1}{i} \pi i(1) = \pi $$
Thank you for your participation, your answer is correct. :)
I forgot to mention in my previous post that there is still an alternative way which does not use the "res" thing used by Random Variable. The challenge is still open. :)
It's called a residue. Someday... ;)
\(\displaystyle I = Re \int^\pi_0 e^{e^{ix}}\,dx = Re \int^\pi_0 \sum_{n\geq 0} \frac{e^{inx}}{n!} \, dx=\int^\pi_0 \sum_{n\geq 0} \frac{\cos(nx)}{n!}=\int^\pi_0 1 \, dx +\int^\pi_0 \sum_{n\geq 1}\frac{\cos(nx)}{n!} \,dx=\pi+0 =\pi\)
Excellent! :cool:
FAQ: Definite Integral challenge #3
What is a definite integral?
A definite integral is a mathematical concept that represents the area under a curve between two specific points, often denoted by the notation ∫abf(x)dx. It is used to calculate the total area enclosed by a curve and the x-axis within a given range.
What is the purpose of "Definite Integral challenge #3"?
The purpose of "Definite Integral challenge #3" is to provide a problem that requires the use of definite integrals to find the area under a specific curve. It is designed to challenge individuals to apply their knowledge of definite integrals and calculus to solve a real-world problem.
How do I solve "Definite Integral challenge #3"?
To solve "Definite Integral challenge #3", you will need to first understand the given problem and identify the interval over which the area needs to be calculated. Then, you will need to set up the definite integral and solve it using integration techniques such as substitution or integration by parts.
What are some common mistakes when solving "Definite Integral challenge #3"?
Some common mistakes when solving "Definite Integral challenge #3" include not properly understanding the given problem, using the incorrect bounds for the integral, and making errors during the integration process. It is important to carefully read and analyze the problem and double-check all calculations to avoid these mistakes.
How can solving "Definite Integral challenge #3" be applied in real life?
Solving "Definite Integral challenge #3" can be applied in various real-life situations, such as calculating the total distance traveled by an object with varying velocity, finding the total water volume in a swimming pool with a curved bottom, or determining the total cost of production for a specific product with changing production rates. It is a useful tool in many fields, including physics, economics, and engineering.
