Definite Integral challenge #4
In summary, the problem is to evaluate $$2^{2009}\frac{\displaystyle \int_0^1 x^{1004}(1-x)^{1004}\,dx}{\displaystyle \int_0^1x^{1004}(1-x^{2010})^{1004}\,dx}$$ without the use of beta or gamma functions. The suggested solution uses elementary approaches and avoids the use of omega or alpha functions. The solution is not provided in order to encourage others to solve the problem.
Saitama
4,243
93
Evaluate:
...of course without the use of beta or gamma functions. :p
Mathematics news on Phys.org
Can we use omega or alpha functions? :rolleyes:
Nope. :P
I should have said that the problem is to be solved by elementary approaches.
Hint:
Integration by parts is a powerful tool.
Krizalid said:
Hint:
Hi Krizalid!
This isn't a homework problem, can you please complete your solution? :rolleyes:
I know, it's just that I know the solution but I want other peoply to try it. :D
Let $\alpha = 1004$ and $\beta=2010$
I will try to calculate the integral:
\[I = 2^{\beta -1}\frac{\int_{0}^{1}x^\alpha (1-x)^\alpha dx}{\int_{0}^{1}x^\alpha (1-x^\beta )^\alpha dx}\]
Calculating the nominator:
\[\int_{0}^{1}x^\alpha (1-x)^\alpha dx = \left [ \frac{1}{\alpha +1}x^{\alpha +1}(1-x)^\alpha \right ]_{0}^{1}+\frac{\alpha }{\alpha +1}\int_{0}^{1}x^{\alpha+1}(1-x)^{\alpha -1}dx \\\\=\frac{\alpha }{\alpha +1}\int_{0}^{1}x^{\alpha+1}(1-x)^{\alpha -1}dx=\frac{\alpha}{\alpha+1}\left ( \left [ \frac{1}{\alpha+2}x^{\alpha+2}(1-x)^{\alpha-1} \right ]_{0}^{1} +\frac{\alpha-1}{\alpha+2}\int_{0}^{1}x^{\alpha+2}(1-x)^{\alpha-2}dx\right) \\\\=\frac{\alpha(\alpha-1)}{(\alpha+1)(\alpha+2)}\int_{0}^{1}x^{\alpha+2}(1-x)^{\alpha-2}dx = ... = \frac{\alpha!}{(\alpha+1)(\alpha+2)...(2\alpha+1)}=\frac{(\alpha!)^2}{(2\alpha+1)!}\]
Calculating the denominator:
\[\int_{0}^{1}x^\alpha (1-x^\beta)^\alpha dx = \left [ \frac{1}{\alpha +1}x^{\alpha +1}(1-x^\beta)^\alpha \right ]_{0}^{1}+\frac{\beta\alpha }{\alpha +1}\int_{0}^{1}x^{\alpha+\beta}(1-x^\beta)^{\alpha -1}dx \\\\=\frac{\beta\alpha }{\alpha +1}\int_{0}^{1}x^{\alpha+\beta}(1-x^\beta)^{\alpha -1}dx=\frac{\beta\alpha}{\alpha+1}\left ( \left [ \frac{1}{\alpha+\beta+1}x^{\alpha+\beta+1}(1-x^\beta)^{\alpha-1} \right ]_{0}^{1} +\frac{\beta(\alpha-1)}{\alpha+\beta+1}\int_{0}^{1}x^{\alpha+2\beta}(1-x)^{\alpha-2}dx\right) \\\\=\frac{\beta^2\alpha(\alpha-1)}{(\alpha+1)(\alpha+1+\beta)}\int_{0}^{1}x^{
\alpha+2\beta}(1-x^\beta)^{\alpha-2}dx\\\\ = \frac{\beta^3\alpha(\alpha-1)(\alpha-2)}{(\alpha+1)(\alpha+1+\beta)(\alpha+1+2\beta)} \int_{0}^{1}x^{\alpha+3\beta}(1-x^\beta)^{\alpha-3}dx= ... = \frac{\beta^{\alpha}\alpha!}{(\alpha+1)(\alpha+1+ \beta)(\alpha+1+2\beta)...(\alpha+1+\alpha\beta)}\]
Thus, the integral can be written:
\[I = 2^{\beta-1}\frac{(\alpha!)^2(\alpha+1)(\alpha+1+\beta)( \alpha+1+2\beta)...(\alpha+1+\alpha\beta)}{\beta^{\alpha}\alpha!(2\alpha+1)!}\]
$I$ can be reduced considerably:
\alpha+1+2\beta)...(\alpha+1+\alpha\beta)}{\beta^{\alpha}\alpha!(2\alpha+1)!} \\\\=2^{\beta-1}\frac{(\alpha+1)!\frac{3}{2}\frac{5}{2}\frac{7}{2}...\frac{2\alpha+1}{2}}{(2\alpha+1)!}=2^{\alpha+1}\frac{(\alpha+1)!(2\alpha+1)!}{(2\alpha+1)!2^{
\alpha}\alpha!}=2(\alpha+1)=\beta = 2010\]
ATTENTION :
lfdahl is using the prohibited beta :p.
Here goes the solution without the use of weird functions. :p
(Suggested solution)
Let
$$N(k)=\int_0^1 x^k(1-x)^k\,dx \,\,\,(*)$$
and
$$D(k)=\int_0^1x^k(1-x^{2k+2})^k\,dx\,\,\,(**)$$
Use the substitution $x^{k+1}=t$ to obtain:
$$D(k)=\frac{1}{k+1}\int_0^1 (1-t^2)^k\,dt$$
$$\Rightarrow \frac{1}{2(k+1)}\int_{-1}^1 (1-t^2)^k\,dt=\frac{2^{2k-1}}{k+1}\int_{-1}^1 \left(\frac{1-x}{2}\right)^k\left(\frac{1+x}{2}\right)^k\,dx$$
Next, use the substitution,
$$\frac{1+x}{2}=u \Rightarrow dx=2du$$
to obtain:
$$D(k)=\frac{2^{2k}}{k+1}\int_0^1 u^k(1-u)^k\,du=\frac{2^{2k}}{k+1} \int_0^1 x^k(1-x)^k\,dx$$
$$D(k)=\frac{2^{2k}}{k+1}N(k)$$
Hence,
$$2^{2k+1}\frac{N(k)}{D(k)}=2(k+1)$$
Since $k=1004$, hence,
$$2^{2009}\frac{N(1004)}{D(1004)}=2(1004+1)=\boxed{2010}$$
Nice solution!
(I miss the thanks button. ;))
Let
and
to obtain:
Hence,
Nice solution indeed! I also miss the thanks-button
FAQ: Definite Integral challenge #4
What is the purpose of "Definite Integral Challenge #4"?
The purpose of "Definite Integral Challenge #4" is to provide a mathematical problem for students and researchers to solve using the concept of definite integrals. It is a way to test and improve one's understanding of this mathematical concept.
What is a definite integral?
A definite integral is a mathematical concept used in calculus to calculate the area under a curve or the total accumulation of a quantity over a specific interval. It is represented by the symbol ∫ and is a fundamental tool in many areas of mathematics and science.
What is the difference between a definite integral and an indefinite integral?
The main difference between a definite integral and an indefinite integral is that a definite integral has specified limits of integration, while an indefinite integral does not. In other words, a definite integral gives a specific numerical value, while an indefinite integral gives a function.
How do you solve a definite integral?
To solve a definite integral, you first need to determine the limits of integration (the upper and lower bounds of the interval). Then, you use the appropriate integration techniques, such as the power rule or substitution, to integrate the function. Finally, you evaluate the integral at the limits of integration to get the numerical value.
Why are definite integrals important in science?
Definite integrals are important in science because they allow us to calculate the total accumulation of a quantity over a specific interval. This is useful in many scientific fields, such as physics, chemistry, and economics, where we need to determine the total amount of something, such as distance, mass, or cost.
