juantheron
- 247
- 1
$\displaystyle \int_{0}^{\frac{\pi}{2}}\frac{\cos x}{(a+b\cos x)^2}dx$
jacks said:$\displaystyle \int_{0}^{\frac{\pi}{2}}\frac{\cos x}{(a+b\cos x)^2}dx$
chisigma said:With the substitution sugggested in...
http://www.mathhelpboards.com/f10/defeinite-integral-2038/#post9364
... You arrive to an integral from 0 to 1 of a rational function...
Kind regards
$\chi$ $\sigma$
A definite integral is a mathematical concept used to calculate the area under a curve between two specified points. It is represented by the symbol ∫ and has a lower and upper limit, which define the interval over which the area is to be calculated.
The limits in a definite integral indicate the starting and ending points for the area calculation. They determine the range of values for which the function will be integrated and the final result will depend on these limits.
To solve a definite integral with trigonometric functions, you can use various techniques such as substitution, integration by parts, or trigonometric identities. In this particular integral, the substitution method would be most appropriate.
The constants "a" and "b" represent the parameters of the given function. They affect the shape, position, and behavior of the graph of the function and can be adjusted to fit different scenarios or real-life applications.
Yes, definite integrals can have negative values. This can occur when the area under the curve is below the x-axis, resulting in a negative area. However, the final result of a definite integral is always a positive value as the negative sign is taken into account during the calculation.
