MHB Definite integral involving sine and hyperbolic sine
The integral $\int_0^{\infty} \frac{\sin x}{\cos x + \cosh x}\, \mathrm dx$ can be evaluated using exponential forms of the sine, cosine, and hyperbolic cosine functions. The sine function is expressed as $\sin(x) = \frac{e^{ix} - e^{-ix}}{2i}$, while cosine and hyperbolic cosine are represented as $\cos(x) = \frac{e^{ix} + e^{-ix}}{2}$ and $\cosh(x) = \frac{e^x + e^{-x}}{2}$, respectively. This transformation simplifies the integral into a more manageable form for calculation. The discussion emphasizes the utility of exponential representations in solving integrals involving trigonometric and hyperbolic functions. Ultimately, the integral can be solved effectively by applying these exponential identities.
MountEvariste
Calculate $\displaystyle \int_0^{\infty} \frac{\sin x}{\cos x + \cosh x}\, \mathrm dx.$
Mathematics news on Phys.org
If nothing else, you can express these functions as exponentials.
$sin(x)= \frac{e^{ix}- e^{-ix}}{2i}$
$cos(x)= \frac{e^{ix}+ e^{-ix}}{2}$
$cosh(x)= \frac{e^x+ e^{-x}}{2}$
Can you derive an infinite series of the integrand using these definitions?
Show that $\displaystyle \frac{\sin x }{\cos x + \cosh x} = i \bigg( \frac{1}{1+e^{ix-x}}-\frac{1}{1+e^{-ix-x}}\bigg)$.
Expand the RHS into geometric series to get, for $x \ge 0$:
$\displaystyle \frac{\sin x}{\cos x + \cosh x}=2\sum_{n=1}^{\infty}(-1)^{n-1}\sin(nx)e^{-nx}.$
Source: Yaghoub Sharifi.
Using the infinite sum in post #4, the answer follows by switching the order of sum and integral and using the result
$\displaystyle \int_0^{\infty} e^{-ax}\sin{bx} \, \mathrm dx =\frac{b}{a^2+b^2}$
Which can be derived via integration by parts or considering the fact that $\Im \left( e^{-ax+ibx} \right) = e^{-ax}\sin bx.$
See a detailed solution in this blog.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
