Definite Integration of a concave upward function- Inequality
In summary: That f(x) is greater than zero, but that seems to be contradictory as a negative function may also have positive derivative. :(Let's begin with:0<f^{\prime\prime}(x)And so, on [1,k] where 1<k\in\mathbb{R} there must be some constant $C$ such that:C<f^{\prime}(x)What happens if you integrate again?If f1(X)>f2(x)doesn't implies that the indefinite integration of f1(x) will be greater than f2(x). This is only applicable when both sides are integrated
mathisfun1
On the last integral, is the upper bound "9"?
Yes.
Hello and welcome to MHB! :D
Can you tell us what you've tried or what your thoughts are on how to begin, so our helpers have an idea where you are stuck and then can provide better help?
Thank you so much!
I began with the condition that the secant must lie above the curve at all points if the curve is concave upward but that seem to lead nowhere. I also tried to utilise the fact that the double derivative of f(X) will be positive but to no avail.
Any help will be appreciated.
I think I would begin with the minimal case:
\(\displaystyle 0<f^{\prime\prime}(x)\)
So, integrating, what can you say about $f$?
Wouldn't integrating this inequality conclude the same thing as what we are given, that f is a concave upward function?
What did you get when integrating?
Let's begin with:
And so, on \(\displaystyle [1,k]\) where \(\displaystyle 1<k\in\mathbb{R}\) there must be some constant $C$ such that:
\(\displaystyle C<f^{\prime}(x)\)
MarkFL said:
Let's begin with:
If f1(X)>f2(x)
doesn't implies that the indefinite integration of f1(x) will be greater than f2(x). This is only applicable when both sides are integrated within limits and thus when integrating from 0 to x, constant gets eliminated.
Let's try another approach...you mentioned that if the function is concave up, then it must lie beneath its secant line, or:
\(\displaystyle f(x)<\frac{f(b)-f(a)}{b-a}(x-a)+f(a)\)
What do you find upon integrating both sides from $a$ to $b$?
FAQ: Definite Integration of a concave upward function- Inequality
What is definite integration of a concave upward function?
Definite integration of a concave upward function is a mathematical process used to calculate the total area between a curve and the x-axis within a specific range of values. This range is defined by the limits of integration, and the resulting value represents the definite integral of the function.
How is definite integration different for a concave upward function compared to a convex upward function?
Definite integration of a concave upward function is similar to that of a convex upward function, except that the area under a concave upward curve is always greater than or equal to the area under the corresponding linear function. This means that the definite integral of a concave upward function will always be a positive value.
What is the significance of a concave upward function in terms of inequalities?
A concave upward function is significant in terms of inequalities because it represents a function that is continuously increasing, but at a decreasing rate. This means that the slope of the function is always positive, but it is becoming less steep as x increases. In terms of inequalities, this means that the left side of the inequality is always greater than the right side.
How can you determine the concavity of a function for definite integration?
The concavity of a function for definite integration can be determined by looking at its second derivative. If the second derivative is positive, the function is concave upward. If the second derivative is negative, the function is concave downward. This information is important in determining the limits of integration and calculating the definite integral.
What are some real-world applications of definite integration of concave upward functions?
Definite integration of concave upward functions has many real-world applications, such as calculating the volume of a container with a curved bottom, finding the area under a demand curve in economics, and determining the total distance traveled by an object with varying acceleration. It is also used in physics to calculate the work done by a non-constant force on an object.
