Definition of a non-polar molecule
In summary: But, if we use a formula to get the center of charges i.e. protons, won't it coincide with the center of charge distribution of protons? So, we don't start with nucleus being a point charge.Yes, that is correct.
vcsharp2003
897
177
Which of the following definitions is the correct definition of a non-polar molecule?
(a) A molecule in which the center of mass of positive charges (i.e. protons) coincides with the center of mass of negative charges (i.e. electrons)
(b) A molecule in which the center of the positive charge distribution coincides with the center of the negative charge distribution
None
I think definition (a) is not correct since the center of charge distribution rather than mass distribution is important here. The correct definition is the one given in (b).
I am thinking that a distribution of charge will have a center of charge ##(x_c,y_c,z_c)## for -ve charges according to following equations ##x_c = \dfrac { \Sigma {q_ix_i}} {\Sigma {q_i}}##, ##y_c = \dfrac { \Sigma {q_iy_i}} {\Sigma {q_i}}## and ##z_c = \dfrac { \Sigma {q_iz_i}} {\Sigma {q_i}}##, where ##q_i## is the absolute value of the magnitude of individual -ve charges. The same formulas can be used for center of positive charge distribution provided ##q_i## is a +ve charge. This center of charge distribution according to above formulas need not necessarily coincide with the center of mass of the charges.
I have used the below formulas of center of mass to come up with the formulas for center of charge distribution. The center of mass distribution ##(x_c,y_c,z_c)## would be given by ##x_c = \dfrac { \Sigma {m_ix_i}} {\Sigma {m_i}}##, ##y_c = \dfrac { \Sigma {m_iy_i}} {\Sigma {m_i}}## and ##z_c = \dfrac { \Sigma {m_iz_i}} {\Sigma {m_i}}##
I am not sure if the formulas for center of charge distribution that I have come up with are correct Also, not sure if definition (a) is an incorrect definition.
I agree with you that (a) is incorrect. Your formulas for centre of charge distribution look correct to me, except that they need to restrict the sums to only positive charges for the positive centre, and negative charges for the negative centre. One way to do that is to replace ##q_i## by ##\max(0, q_i)## in both the numerator and denominator in the formula for positive centre, and by ##\min(0,q_i)## for negative centre.
Likes vcsharp2003
After giving it some more thought, it seems to me that center of mass for the +ve charges would coincide with their center of charge distribution. The same would also apply to the -ve charges. The reason why I say this is because the charge to mass ratio ##k## is a constant for a proton and also a constant for an electron, and therefore if one substitutes ##q_i= km_i## in the formulas for the center of charge distribution that I gave in my OP, then the factor ##k## will cancel in the numerator and denominator leaving us with the same formulas as those of the center of mass.
Does above sound correct?
It would certainly be approximately correct. I'm not sure whether it would be exactly correct. In nuclear reactions the number of nucleons does not change but the total weight of the nuclei does. So I am not sure we can assume that protons always weigh the same regardless of what type of nucleus they are in.
I'd stick with the charge-based definition. There's just no need to introduce the concept of mass, and it might cause problems.
Likes vcsharp2003
vcsharp2003 said:
After giving it some more thought, it seems to me that center of mass for the +ve charges would coincide with their center of charge distribution. The same would also apply to the -ve charges. . .
Yes, it sounds correct to me. The question seems poorly written as both choices (a) and (b) can be interpreted as true.
Likes vcsharp2003
One usually takes the nucleus to be a point charge, so in that case the centre of mass often differs from the centre of positive charge.
Likes vcsharp2003
Yes. My point was that this is not how things are usually done (you don't consider individual protons).
I should also have added that I have never seen a definition of a dipole moment that took into account the mass of the charges.
Likes vcsharp2003
FAQ: Definition of a non-polar molecule
What is a non-polar molecule?
A non-polar molecule is a molecule in which the electrons are distributed more symmetrically and thus does not have an abundance of charges at opposite ends. The electron distribution leads to no significant dipole moment, meaning the molecule has no partial positive or negative charges.
How do non-polar molecules differ from polar molecules?
Non-polar molecules have an even distribution of electrons, resulting in no significant charge difference across the molecule. In contrast, polar molecules have an uneven distribution of electrons, leading to regions of partial positive and negative charges due to differences in electronegativity between bonded atoms.
What are some common examples of non-polar molecules?
Common examples of non-polar molecules include diatomic gases like nitrogen (N2) and oxygen (O2), as well as organic molecules like methane (CH4) and carbon dioxide (CO2).
How can you determine if a molecule is non-polar?
You can determine if a molecule is non-polar by examining its molecular geometry and the electronegativity of its atoms. If the molecule is symmetrical and the atoms have similar electronegativities, the molecule is likely non-polar. Additionally, if the molecule lacks a net dipole moment, it is non-polar.
Why are non-polar molecules insoluble in water?
Non-polar molecules are insoluble in water because water is a polar solvent. Polar solvents dissolve polar substances well due to the attraction between opposite charges. Since non-polar molecules lack these charges, they do not interact favorably with water molecules and therefore do not dissolve well in water.
