Definition of centripetal force
In summary, the centripetal force is the net force acting perpendicular to the instantaneous velocity in uniform circular motion. In non-uniform circular motion, there is also a net force parallel to the instantaneous velocity. However, the centripetal force is always perpendicular to the instantaneous velocity, as it is the force required to keep the object at a constant distance from a given axis. It is not an applied force.
MBBphys
Hi,
If an object is undergoing uniform circular motion, then the net force is acting perpendicular to the instantaneous velocity, and this is called the centripetal force.
However, if the object is moving in a circle but the magnitude of its instantaneous velocity is not constant, then there must be a net force parallel to the instantaneous velocity, in addition to a net force perpendicular to the instantaneous velocity which makes it go in a circle.
My question is: in the second scenario, is the centripetal force the net force perpendicular to the instantaneous velocity, or is it the resultant force of adding the parallel and perpendicular "net forces", and so the centripetal force would not be wholly perpendicular to the instantaneous velocity?
Which is it?
In essence, is the centripetal force always perpendicular to the instantaneous velocity, or if the object is undergoing non-uniform circular motion, would the centripetal force not be wholly perpendicular to the instantaneous velocity?
Thanks a lot in advance!
F=(mv2/r)
N/A
Centripetal means "towards the centre" so it's only that component.
Thank you!
It might also help to bear in mind that the centripetal force is not an applied force; it is the force that would be required to keep the object at a constant distance from a given axis (even if it is not staying at a constant distance).
Likes CWatters
Related to Definition of centripetal force
What is the definition of centripetal force?
Centripetal force is the force that acts on an object moving in a circular path, directed towards the center of the circle.
How is centripetal force different from centrifugal force?
Centripetal force is a real force that acts on an object, while centrifugal force is a perceived force that arises due to the inertia of the object.
What is the formula for calculating centripetal force?
The formula for calculating centripetal force is F = mv²/r, where F is the force, m is the mass of the object, v is its velocity, and r is the radius of the circular path.
Can centripetal force act on an object in a straight line?
No, centripetal force is always directed towards the center of the circle in which the object is moving. If the force is acting in a straight line, it is not considered a centripetal force.
How is centripetal force related to centripetal acceleration?
Centripetal force and centripetal acceleration are directly proportional to each other. This means that as the centripetal force increases, the centripetal acceleration also increases, and vice versa.
