Definition of Form-Invariant Function: Q&A
  • Thread starter Einj
  • Tags
    Definition
In summary, a form-invariant function is a metric that remains the same function under a given coordinate transformation. This means that the transformed metric and the original metric are the same function of their respective arguments. This is different from just having the same value at a single point, as the two functions must have the same form in order to be considered form-invariant. This is why the symbol "y" is used instead of "x" in the definition.
Einj
470
59
Hello everyone. I'm reading Weinberg's 'Gravitation and Cosmology' and I'm having some problems understanding the definition of a 'form-invariat function'. He says:
A metric ##g_{\mu\nu}## is said to be form-invariant under a given coordinate transformation ##x\to x^\prime##, when the transformed metric ##g^\prime_{\mu\nu}(x^\prime)## is the same function of its argument ##x^{\prime\mu}## as the original metric ##g_{\mu\nu}(x)## was of its argument ##x^\mu##, that is,
\begin{equation}
g^\prime_{\mu\nu}(y)=g_{\mu\nu}(y) \; \text{ for all }y.
\end{equation}
If the previous condition was true doesn't this simply mean that ##g_{\mu\nu}^\prime## is the same function as ##g_{\mu\nu}##? Should we ask for:
\begin{equation}
g^\prime_{\mu\nu}(x^\prime)=g_{\mu\nu}(x)
\end{equation}
Thanks a lot!
That is precisely what he means, that they are the same function.
I think that's why he used the symbol "y" instead of x's, so that it wouldn't be confused as having something to do with the coordinates x and x'.
The problem with [itex] g'_{\mu\nu}(x')=g_{\mu\nu}(x) [/itex] is that it means the two functions have same value in a single point. But because [itex] x' [/itex] associates different numbers to that point compared to [itex] x [/itex], [itex] g'_{\mu\nu}(x')=g_{\mu\nu}(x) [/itex] necessarily means [itex] g [/itex] and [itex] g' [/itex] are different functions and don't have the same form.
But [itex] g'_{\mu\nu}(y)=g_{\mu\nu}(y) [/itex] means that if we give the two functions, the same numbers, they will give equal results which means they're the same function. Note that y in the right refers to a different point than y in the left because they are same numbers in different coordinate systems.
Likes Einj
Oh I see. That is clear. Thanks!
Hello,
Thank you for your question. I can provide you with a response to help clarify the definition of a form-invariant function.
Firstly, a form-invariant function is a mathematical concept that is used in the study of general relativity. In this context, a form-invariant function refers to a function that remains unchanged under a given coordinate transformation.
In the definition provided, the transformed metric ##g^\prime_{\mu\nu}(x^\prime)## is said to be the same function of its argument ##x^{\prime\mu}## as the original metric ##g_{\mu\nu}(x)## was of its argument ##x^\mu##. This means that the two metrics, the original and the transformed, have the same functional form. However, the arguments of the two metrics are different, as one is in the original coordinate system and the other is in the transformed coordinate system.
To answer your question, yes, the condition ##g^\prime_{\mu\nu}(y)=g_{\mu\nu}(y)## does mean that the two metrics are the same function. However, to be more precise, we should ask for the condition ##g^\prime_{\mu\nu}(x^\prime)=g_{\mu\nu}(x)##, as this takes into account the fact that the arguments of the two metrics are different due to the coordinate transformation.
I hope this helps clarify the definition of a form-invariant function for you. If you have any further questions, please don't hesitate to ask.
FAQ: Definition of Form-Invariant Function: Q&A
1. What is a form-invariant function?
A form-invariant function is a mathematical concept where the output of the function remains unchanged even when the input is transformed in some way. This means that the function follows a specific pattern or structure that is not affected by changes in the input.
2. How is a form-invariant function different from other types of functions?
A form-invariant function is unique in that its output remains unchanged, regardless of any transformations applied to the input. Other types of functions may have varying outputs depending on the input.
3. Can you provide an example of a form-invariant function?
One example of a form-invariant function is the quadratic equation y = x2. No matter what value is plugged in for x, the output will always be a perfect square.
4. What are some practical applications of form-invariant functions?
Form-invariant functions can be used in various fields such as physics, engineering, and computer science. They are particularly useful in situations where certain properties or patterns need to remain constant despite changes in the input.
5. Are there any limitations to form-invariant functions?
While form-invariant functions can be useful in certain situations, they are not applicable to all types of functions. Additionally, some transformations may still affect the output of a form-invariant function, so it is important to carefully consider the specific function and transformations involved.
