LarryS
- 33
I understand the definitions of both the classical and relativistic (SR) Lagrangians. But I cannot find a precise mathematical definition of Lagrangian Density. Please assist. Thanks in advance.
The_Duck said:In classical or quantum field theory you tend to write the Lagrangian of your system as an integral of some expression over all space. The integrand is the Lagrangian density. In the same way, total mass is the integral of mass density over space. But maybe you wanted something deeper?
The_Duck said:
A Lagrangian density is a mathematical quantity used in theoretical physics to describe the dynamics of a physical system. It is defined as the Lagrangian per unit volume, and is used to calculate the equations of motion for a system.
Lagrangian density is a generalization of Lagrangian mechanics, which is a mathematical framework for analyzing the motion of a system without considering the forces acting on it. Lagrangian density takes into account the entire volume of a system, while Lagrangian mechanics only considers the motion of individual particles.
Lagrangian density is a fundamental concept in physics, as it allows for the formulation of the Euler-Lagrange equations, which describe the dynamics of a system. It is used in various fields of physics, including classical mechanics, quantum field theory, and general relativity.
Lagrangian density and Hamiltonian density are two different mathematical quantities used to describe the dynamics of a system. While Lagrangian density is defined as the Lagrangian per unit volume, Hamiltonian density is defined as the Hamiltonian per unit volume. Hamiltonian density is used in Hamiltonian mechanics, which is another mathematical framework for analyzing the motion of a system.
Lagrangian density is a crucial concept in quantum field theory, as it is used to formulate the equations of motion for quantum fields. It is an essential tool for understanding the behavior of particles at the quantum level and has applications in particle physics, condensed matter physics, and cosmology.
