- #36
gracy
- 2,486
- 83
what?please guidejtbell said:Something seems to be missing from that equation.
If you slide down a hill on a sled with rusty runners do you have the same kinetic energy as when you slide down on one with freshly waxed runners?gracy said:Please tell me if there is only conservative force present i.e ##Wconservative##=##Wnet##
in such conditions the below formula is always applicable
##Wconservative##=##-ΔPE##=##ΔKE##
I THINK, NO.jbriggs444 said:If you slide down a hill on a sled with rusty runners do you have the same kinetic energy as when you slide down on one with freshly waxed runners?
I apologize. My snarky comment had ignored your caveats that no non-conservative force was involved. So no rusty runners for your sled. And the equation does hold.gracy said:I THINK, NO.
Mark (notice) my word "always"gracy said:in such conditions the below formula is always applicable
WconservativeWconservative=−ΔPE-ΔPE=ΔKE
Butjbriggs444 said:However, the work done by a non-conservative force on an object moving in its field can have nothing whatsoever to do with the change in potential energy between the starting point and the ending point for the simple reason that there is no such thing as potential energy in a non-conservative field.
gracy said:so there seems to be relation between Work due to non- conservative forces and potential energy atleast mathematically
No.jtbell said:Can you describe a specific situation in which you think it doesn't apply?
gracy said:##Wnonconservative##=##ΔKE##+##ΔPE##
The work-energy theorem, derived from Newton’s second law, applies to the displacement of a particle or the center of mass of an extended body treated as a particle. Because work, as a quantity of energy transferred in accordance with the First Law of Thermodynamics, cannot be calculated in general as an applied force times the displacement of center of mass, the work-energy theorem is not a valid statement about energy transformations when work is done against a frictional force or actions on or by deformable bodies. To use work in conservation of energy calculations, work must be calculated as the sum of the products of forces and their corresponding displacements at locations where the forces are applied at the periphery of the system under consideration. Failure to make this conceptual distinction results in various errors and misleading statements widely prevalent in textbooks, thus reinforcing confusion about energy transformations associated with the action in everyday experience of zero-work forces such as those present in walking, running, jumping, or accelerating a car. Without a thermodynamically valid definition of work, it is also impossible to give a correct description of the connection between mechanical and thermal energy changes and of dissipative effects. The situation can be simply corrected and student understanding of the energy concepts greatly enhanced by introducing and using the concept of internal energy, that is, articulating the First Law of Thermodynamics in a simple, phenomenological form without unnecessary mathematical encumbrances.
gracy said:Ok.There is a question.A charge s moved in an electric field of a fixed charge distribution from point A to another point B SLOWLY.The work done by external agent /force in doing so is 100J.Find the work done by external agent/force.
Here we are not told whether this external force is conservative or non conservative.But I think I will suppose it to be non conservative because in our portion /syllabus there are only three types of conservative forces spring force,electric field force and gravitational force.As I a m taking it to be non conservative
I can apply the formula below
##Wnc##=##Wextenal##=##ΔPE##+##ΔKE##
But the question indirectly indicates that there is no change in kinetic energy by the term :slowly"(I have created separate thread on it)
So the equation becomes
##Wnc##=##Wextenal##=##ΔPE##=100J
My answer is correct.I know the other method to solve this also
as explained by @jbriggs444.But I want to know is the above method also correct?
It does not matter whether the external force is or is not conservative. It is a force. It does work. That is all that matters. However, the question of whether it is conservative or not can be answered using only the information from the problem statement.gracy said:Ok.There is a question.A charge s moved in an electric field of a fixed charge distribution from point A to another point B SLOWLY.The work done by external agent /force in doing so is 100J.Find the work done by external agent/force.
Hi Gracy,gracy said:But
##Wnet##=##Wconservative##+##Wnonconservative##
##Wnet##=##ΔKE##
(WORK ENERGY THEOREM)
(definition of potential energy)
hence we can derive from above equations
##Wnnconservative##=##Wnet## - ##Wconservative##
=##ΔKE## - (##-ΔPE##)
=##ΔKE##+##ΔPE##
so there seems to be relation between Work due to non- conservative forces and potential energy atleast mathematically (as we know mathematics is language of physics)
What is a1 here?jbriggs444 said:Factoring a -1 out of the integral,
Minus 1. Written as -1.gracy said:What is a1 here?
##∫FdS##=-##∫FdS##jbriggs444 said:If the one integral is independent of path then the other must be as well. If the one force is conservative then the other must be (at least approximately) conservative as well.
It is poor form to use the same letter in the same equation to denote two different things.gracy said:##∫FdS##=-##∫FdS##
You meant if F of right hand side is conservative F of left hand side has to be conservative as well?
jbriggs444 said:Factoring a -1 out of the integral, it is immediately obvious that the work done by the external force is equal and opposite to the work done by the electrostatic force.
gracy said:Here we are not told whether this external force is conservative or non conservative.But I think I will suppose it to be non conservative because in our portion /syllabus there are only three types of conservative forces spring force,electric field force and gravitational force.
Mister T said:The work done by the electrostatic force is path independent. The work done by the other need not be. It could be, for example, that had a different path been taken the total work done might not be zero.
jbriggs444 said:So the force applied by our hands must indeed always be equal and opposite to the electrostatic force at every place (and time) where it is applied.
