Definition of $S_n$ for Cantor-Schröder-Bernstein Theorem
  • MHB
  • Thread starter evinda
  • Tags
    Definition
In summary, the definition of $S_n$ in the proof of the Cantor-Schröder-Bernstein theorem is given inductively, with $S_0$ starting as $A-g(B)$ and $S_{n+1}$ being defined as $g[f[S_n]]$ for all $n \in \omega$.
evinda
MHB
3,836
Hi! (Smile)
I am looking at the proof of the theorem of Cantor- Schröder-Bernstein, that states the following:
Let $A,B$ be sets. If $A$ is equinumerous with a subset of $B$ and $B$ is equinumerous with a subset of $A$ then $A, B$ are equinumerous. Or equivalently, if $f: A \overset{1-1}{B}$ and $g: B \overset{1-1}{A}$ then there is a $h: A \overset{\text{surjective}}{\to}B$.
Proof:
Let $f: A \overset{1-1}{\to}B$ and $g: B \overset{1-1}{\to}A$.
We define recursively the following sequence of sets:
$$S_0:=A-g(B)\\S_{n+1}=g[f[S_n]]\\ \text{ for all } n \in \omega \\ \dots$$
We define $S:=\bigcup_{n \in \omega} S_n$ and the function $h: A \to B$ as follows:
$$f(x)=x \text{ if } x \in S \\ h(x)=g^{-1}(x) \text{ if } x \in A-S$$
Could you explain me the definition of $S_n$?
evinda said:
Hi! (Smile)
Proof:
Hi evinda.
You have defined $S_n$ inductively by declaring:
Where exactly are you facing a problem?
FAQ: Definition of $S_n$ for Cantor-Schröder-Bernstein Theorem
What is the definition of $S_n$ in the Cantor-Schröder-Bernstein Theorem?
In the Cantor-Schröder-Bernstein Theorem, $S_n$ refers to the set of all possible combinations of elements from two sets, $A$ and $B$, such that each combination contains exactly $n$ elements. These combinations are called $n$-tuples.
How is $S_n$ used in the proof of the Cantor-Schröder-Bernstein Theorem?
In the proof of the Cantor-Schröder-Bernstein Theorem, $S_n$ is used to show that if there is a one-to-one mapping between sets $A$ and $B$ using $n$-tuples, then there must also be a one-to-one mapping between the power sets of $A$ and $B$. This is a key step in demonstrating the existence of a bijection between the two sets.
Can you give an example of $S_n$ in the context of the Cantor-Schröder-Bernstein Theorem?
For example, if we have two sets $A = \{1,2,3\}$ and $B = \{a,b,c\}$, then $S_2$ would consist of the following 2-tuples: $\{(1,a),(1,b),(1,c),(2,a),(2,b),(2,c),(3,a),(3,b),(3,c)\}$. This set represents all possible combinations of elements from $A$ and $B$ in pairs.
How does the definition of $S_n$ relate to the concept of cardinality?
The definition of $S_n$ is closely related to the concept of cardinality, as it represents the different ways in which elements from two sets can be combined. In the Cantor-Schröder-Bernstein Theorem, $S_n$ is used to demonstrate that if there is a one-to-one mapping between sets $A$ and $B$ using $n$-tuples, then the two sets must have the same cardinality.
Why is $S_n$ an important part of the Cantor-Schröder-Bernstein Theorem?
$S_n$ is an important part of the Cantor-Schröder-Bernstein Theorem because it allows us to show the existence of a bijection between two sets, which is essential in proving that the two sets have the same cardinality. Without the use of $S_n$, it would be much more difficult to demonstrate the existence of this bijection and ultimately prove the theorem.
