Definition of the extrinsic-curvature tensor.
In summary, the extrinsic curvature tensor can be defined in multiple ways, but ultimately describes the change of the unit normal vector away from a hypersurface. It is often projected onto the hypersurface to simplify calculations and has a clear geometric interpretation in terms of the induced derivative operator. Suggestions for further reading include chapters 9 and 10 of Wald.
center o bass
560
Some define the extrinsic curvature tensor as
$$K_{\mu \nu} = h^{\ \ \ \sigma}_\nu h^{\ \ \ \lambda}_\nu \nabla_\sigma n_\lambda.$$
From the expression it seems like the index of the covariant derivative in can be any spacetime index. However, does it makes sense to ask what the covariant derivative of the normal vector n to a hypersurface, when n is only defined at the surface? How does one make sense of the change in n away from the hypersurface?
That's the whole point of projecting the space-time indices of ##\nabla_{a}n_{b}## onto spatial indices relative to ##h_{ab}##. ##\nabla_{a}n_{b}## by itself may not be well-defined since we won't necessarily know how ##n^{a}## varies off of the hypersurface ##\Sigma## but ##h_{a}{}{}^{c}h_{b}{}{}^{d}\nabla_{c}n_{d}## has only spatial indices and as such lies entirely within ##\Sigma## thus this derivative only requires information of how ##n^{a}## varies on ##\Sigma## itself.
In other words, ##h_{ab}## and ##\nabla_a## induce a derivative operator on ##\Sigma## itself, denoted ##\tilde{\nabla}_a##, defined by ##\tilde{\nabla}_c T^{a_1...a_k}{}{}_{b_1...b_l} = h_{d_1}{}{}^{a_1}...h_{b_l}{}{}^{e_l}h_{c}{}{}^{f}\nabla_{f}T^{d_1...d_k}{}{}_{e_1...e_l}##.
But from the definition it seems like the derivative is acting first and then it's projected. Does the projection of a not necessarily defined vector then become well defined?
Another author defined the extrinsic curvature as
$$K_{ab} = \vec{e}_b \cdot \nabla_a \vec{n}$$
where latin indicies are associated with the hypersurface and greek indicies are associated with the ambient manifold. He states that the that the covariant derivative is to be taken in the full manifold. Are these two definitions somehow equivalent?
(BTW: Do you have any suggestions on where to read about these things? :) )
You act on the tensor field with ##h_{a}{}{}^{b}\nabla_{b}## so the projection of the derivative operator onto ##\Sigma## has already been done.
Also keep in mind that usually ##n^a## is defined as the unit normal field in space-time to a one-parameter family ##\Sigma_t## of space-like hypersurfaces foliating space-time, in which case ##\nabla_a n_b## is well defined on all of space-time and ##h_{a}{}{}^{b}\nabla_{b}n_{c}## is simply the tangential component of ##\nabla_a n_b## along ##\Sigma_t## for any ##t##.
In such a case, the extrinsic curvature would simply be defined as ##K_{ab} = h_{a}{}{}^{c}\nabla_c n_b##. This has a very clear geometric interpretation as follows. First note that ##n^a## is hypersurface orthogonal i.e. ##n_{[a}\nabla_{b}n_{c]} = 0##; also, since ##n^a## has length unity, we have that ##n^b \nabla_a n_b = 0##. Thus ##\mathcal{L}_{n}h_{ab} = n^{c}\nabla_{c}h_{ab} + h_{cb}\nabla_a n^c + h_{ac}\nabla_{b}n^c\\ = n^{c}n_b\nabla_{c}n_a + n^{c}n_a\nabla_{c}n_b + \nabla_a n_b + \nabla_b n_a\\ = 2(n_a n^c \nabla_c n_b + \nabla_a n_b )\\ = 2h_{a}{}{}^{c}\nabla_c n_b = 2K_{ab}##.
Now choose Gaussian normal coordinates (i.e. coordinates adapted to ##\Sigma_t##) so that the components of the unit normal field become ##n^{\mu} = \delta^{\mu}_t##. Then ##K_{\mu\nu} = \frac{1}{2}\partial_{t}h_{\mu\nu}##.
What is ##\vec{e}_b##?
See chapters 9 and 10 of Wald (particularly chapter 10).
To take a covariant derivative one only needs to know the vector field along a curve. One knows the unit normal along any curve on the hypersurface.
Away from the hypersurface you would need to extend the normal to a neighborhood of the hypersurface. For small distance it is possible to do this without creating singularities( if the hypersurface is compact)
The covariant derivative of the unit normal with respect to a tangent vector to the hypersurface is itself tangent to the hypersurface. This follows because the connection is compatible with the metric.
Specifically, if X is a tangent vector then X.<N,N> = 0 (since <N,N> = 1) = 2<∇[itex]_{X}N[/itex],N>
The extrinsic curvature can be expressed in two ways
K(X,Y) = <∇[itex]_{X}N[/itex],Y> and
K(X,Y) = -<∇[itex]_{X}Y[/itex],N>
Equality of these two expressions follows by expanding the derivative X.<Y,N> in terms of the connection.
Related to Definition of the extrinsic-curvature tensor.
1. What is the extrinsic-curvature tensor?
The extrinsic-curvature tensor is a mathematical object used in the field of differential geometry to describe the curvature of a hypersurface embedded in a higher-dimensional space. It measures how much a surface curves in the surrounding space.
2. How is the extrinsic-curvature tensor calculated?
The extrinsic-curvature tensor is calculated using the first and second fundamental forms of the hypersurface. These forms are derived from the metric tensor of the higher-dimensional space and the parametric equations of the hypersurface.
3. What is the significance of the extrinsic-curvature tensor?
The extrinsic-curvature tensor is significant because it provides a way to measure the curvature of a hypersurface without having to consider the higher-dimensional space it is embedded in. This makes it a useful tool in various fields such as general relativity, differential geometry, and material science.
4. How is the extrinsic-curvature tensor related to the intrinsic-curvature tensor?
The extrinsic-curvature tensor and the intrinsic-curvature tensor are related through the Gauss-Codazzi equations, which describe the relationship between the curvature of a hypersurface and the curvature of the surrounding space. The extrinsic-curvature tensor is also used to calculate the Ricci tensor, which is a component of the intrinsic-curvature tensor.
5. Can the extrinsic-curvature tensor be negative?
Yes, the extrinsic-curvature tensor can have negative values. This indicates that the hypersurface is negatively curved, meaning it curves in the opposite direction of the surrounding space. However, the magnitude of the extrinsic-curvature tensor is what is most important in determining the curvature of the hypersurface.
  • Differential Geometry
