Definition of unconnected subgroups
  • Thread starter PsychonautQQ
  • Tags
    Definition
In summary, the intersection of any two subgroups is {1} if and only if the vectors are linearly independent.
PsychonautQQ
784
M = intersection.
Textbook:
"The following are equivalent for subgroups G1, G2, ... ,GN of a group.
1) (G1*G2*...*G(K-1)) M GK = {1} for each k=2,3,...,n
2) If g1*g2*...*gn = 1, where each gi is an element of Gi, then gi = 1 for each i."
If these conditions are met then the subgroups are called unconnected.
My question is this: Isn't this just the same as saying that the intersection of any two subgroups is {1}? If not, why? What's the difference?
No, it's not the same. Consider for example the group ##G = C_2 \times C_2##, the non-cyclic abelian group with four elements. It has three subgroups of order 2, let's call them ##H_1, H_2, H_3##. Pairwise, they satisfy ##H_j \cap H_k = \{1\}## if ##j \neq k##. But the product of any two of them is all of ##G##, so they do not satisfy the condition ##(H_1 H_2) \cap H_3 = \{1\}##. In fact, ##(H_1 H_2) \cap H_3 = G \cap H_3 = H_3##.
Likes PsychonautQQ
Interesting, thank you. What exactly are the subgroups of C2 x C2? are they (C2 x 0), (0 x C2) and then maybe C2 x C2 itself?
If we write the elements of ##C_2## as ##\{1, a\}##, then the elements of ##C_2 \times C_2## are ##\{(1,1), (a,1), (1,a), (a,a)\}##. The first element ##(1,1)## is the identity; the other three have order ##2## and therefore each one generates a subgroup of order ##2##:
$$\begin{aligned}
H_1 &= \langle (a,1) \rangle = \{(1,1), (a,1)\} \\
H_2 &= \langle (1,a) \rangle = \{(1,1), (1,a)\} \\
H_3 &= \langle (a,a) \rangle = \{(1,1), (a,a)\} \\
\end{aligned}$$
If you prefer additive notation, then write ##0## instead of ##1## above.
Likes PsychonautQQ
Thanks, I appreciate it
Here is another example, more geometric. As it is known, ##\mathbb R^N## (or any vector space) with addition is an abelian group (group operation is the vector space addition, unit is the zero vector). Let ##\mathbf a_1, \mathbf a_2, \ldots, \mathbf a_n## be non-zero vectors in ##\mathbb R^N## (we do not assume ##n=N##), and let ##G_k## be the subspaces generated by ##\mathbf a_k##, $$G_k = \{ x\mathbf a_k: x\in\mathbb R\}.$$ Then ##G_k## is a subgroup of the group ##\mathbb R^N##. And it is not hard to check that the subgroups ##G_1, G_2, \ldots, G_n## are unconnected if and only if the vectors ##\mathbf a_1, \mathbf a_2, \ldots, \mathbf a_n## are linearly independent. And any two subgroups have trivial intersection means simply that no two vectors ##\mathbf a_k## are collinear, i.e. that no vector ##\mathbf a_k## is a multiple of another vector ##\mathbf a_j##, ##j\ne k##. And that condition is much weaker than linear independence, you can find bunch of examples even in ##\mathbb R^2##.
Likes PsychonautQQ
Thanks Hawkeye, that helped alot.
Related to Definition of unconnected subgroups
What is the definition of unconnected subgroups?
The term "unconnected subgroups" refers to groups or subpopulations within a larger population that have little or no interaction or connection with each other. These subgroups may be defined by various characteristics such as geographical location, social status, or cultural beliefs.
How do unconnected subgroups affect research studies?
Unconnected subgroups can significantly impact research studies by introducing bias and limiting the generalizability of results. If these subgroups are not accounted for, the findings may not accurately reflect the entire population being studied.
What are some examples of unconnected subgroups?
Examples of unconnected subgroups may include marginalized communities, different ethnic or racial groups, individuals with different socioeconomic backgrounds, or people with varying political beliefs.
Why is it important to identify unconnected subgroups in research?
Identifying unconnected subgroups is crucial in research because it allows for a more comprehensive understanding of the population being studied. It also helps researchers to identify potential variables that may influence the results and to develop more accurate and inclusive conclusions.
How can researchers address unconnected subgroups in their studies?
Researchers can address unconnected subgroups in their studies by intentionally recruiting participants from different subgroups, conducting subgroup analyses, and acknowledging and discussing any potential limitations of their findings due to unconnected subgroups.
  • Linear and Abstract Algebra
