Definitions of Functions and Spaces
In summary: R}^1$ is the set of numbers that are just the numbers on the number line, and $\mathbb{R}^2$ is the set of numbers that are the sum of the numbers on the number line and the number two after that. So, the difference between $x\in\mathbb{R}^n$ and $x \in \mathbb{R}$ is that $x\in\mathbb{R}^n$ means that $x$ is a vector in $\mathbb{R}^n$, and $x \in \mathbb{R}$ means that $x$ is a real number.
imfromyemen
Hi everyone,
I am in second year university and am taking linear algebra this semester. Never having been a strong maths student, I am certainly struggling with some basic concepts and especially notation.
I have tried searching on the web but have had difficulty in finding something which properly explains the meaning of notation like
$$ f: \Bbb{R^2} \to \Bbb{R}$$ or the difference between
$x\in \Bbb{R^n}$ and $x \in \Bbb{R}$I can basically read these, and know the literal pronounciation of the symbols, but have no idea what they actually mean.
The first one would be $f$ maps $\Bbb{R^2}$ to $\Bbb{R}$. What does this mean exactly?
Is it saying that on an (x,y) plane, the function f returns a single point?
so for example - f(x) = 4x, then f(1) = 4
is the second one saying that x is an element of a vector space with n elements $(ax_1, bx_2,...,a_nx_n)$, whereas the first one is saying that x is just some real number?
I would really appreciate if someone could help me with this, I want to do really well in mathematics and not being able to understand these little things is making everything much more difficult than it need be.
kind regards
kind regards
Hello! (Smile)
The notation $f:\mathbb{R}^2 \rightarrow \mathbb{R}$ means that $f$ is a function whose domain is $\mathbb{R}^2$, the set of real $2-$vectors, and whose range is some subset of $\mathbb{R}$, possibly but not necessarily all of $\mathbb{R}$.
An example of such a function is the following: $f(x, y)=x^2y$. $\mathbb{R}^n$ is the set of ordered $n-$tuples of real numbers, $$\mathbb{R}^n=\{(x_1, x_2, \dots , x_n): x_1, x_2, \dots , x_n \in \mathbb{R}\}$$
The elements of $\mathbb{R}^n$ are called vectors. Given a vector $x=(x_1, x_2 \dots , x_n)$, the numbers $x_1, x_2 , \dots , x_n$ are called components of $x$.
At the definition of $\mathbb{R}^n$, for $n=1$ we get $\mathbb{R}^1=\mathbb{R}$ which can be interpreted as the number line.
In other words, $\mathbb{R}$ is the set of real numbers.
FAQ: Definitions of Functions and Spaces
What is a function?
A function is a mathematical relationship between inputs and outputs. It takes in one or more inputs, performs a specific operation or set of operations, and produces an output.
What is the domain of a function?
The domain of a function is the set of all possible input values that the function can take. It is often represented by the variable x and is found on the horizontal axis of a graph.
What is the range of a function?
The range of a function is the set of all possible output values that the function can produce. It is often represented by the variable y and is found on the vertical axis of a graph.
What is a vector space?
A vector space is a set of objects, called vectors, that can be added and multiplied by scalars (usually numbers) to produce new vectors. It follows certain rules and properties, such as closure under addition and scalar multiplication, and has a zero vector and additive inverses for every vector.
What is the difference between a vector space and a function space?
A function space is a type of vector space where the objects are functions instead of traditional vectors. This means that the operations of addition and scalar multiplication are defined for functions, and the resulting functions must also follow certain rules and properties. In other words, a function space is a vector space with functions as its elements.
