Deflection due to Magnetic Field
In summary, the deflection of the electron beam in a tube TV set is achieved through magnetic forces by accelerating each electron through a potential difference of 30000V. The charge to mass ratio of the electron is 175824175824.176C/kg. To determine the distance from the center of the screen where the beam strikes, we can use the equations R = mv/qB and R = (m/eB)*√(2eVacc/m). However, the question seems to be missing some information, such as the required magnetic field to produce a deflection of 0.03m at a magnetic field region length of 0.065m.
Alouette
35
The deflection of the electron beam in an old-fashioned tube TV set is accomplished by magnetic forces. Each electron is accelerated through a potential difference of V=30000V. The charge to mass ratio of the electron is 175824175824.176C/kg.
If there is a x2=0.1m gap between the end of the magnetic field region and the end of the tube, how far from the center of the screen does the beam strike?
ynet = y1 + y2 =
R = mv/qB
I'm not even sure where to begin. The first thing I'm confused by is what do they mean by end of magnetic field region?
Im having the same problem as above with the same question.
it just that the question above seem to be missing a line of information which is
What magnetic field is required to produce a deflection of y1=0.03m if the magnetic field region is x1=0.065m long?
Related to Deflection due to Magnetic Field
1. What is deflection due to magnetic field?
Deflection due to magnetic field is the phenomenon where a charged particle, such as an electron, is pushed off its original path by the presence of a magnetic field.
2. How does deflection due to magnetic field occur?
Deflection due to magnetic field occurs because when a charged particle moves through a magnetic field, it experiences a force perpendicular to both its own velocity and the magnetic field. This force causes the particle to change its direction of motion and become deflected.
3. What factors affect the degree of deflection?
The degree of deflection depends on the strength of the magnetic field, the charge of the particle, and the velocity of the particle. A stronger magnetic field, higher charge, and higher velocity will result in a greater degree of deflection.
4. What is the use of deflection due to magnetic field in scientific research?
Deflection due to magnetic field is used in scientific research to study the properties of charged particles, such as their charge-to-mass ratio and energy. It is also used in various technologies, such as particle accelerators and mass spectrometers.
5. How is deflection due to magnetic field different from deflection due to electric field?
Deflection due to magnetic field and deflection due to electric field are both caused by the presence of a force acting on a charged particle. However, the direction of the deflection is different. In a magnetic field, the deflection is perpendicular to the direction of motion, while in an electric field, the deflection is parallel to the direction of motion.
