Degenerate Perturbation Theory
In summary, the conversation discusses the application of degenerate perturbation theory in quantum mechanics, specifically in the context of a two state system. The approach involves diagonalizing the perturbation in the subspace of degenerate states, which ensures that the perturbation is diagonal and allows for the use of first order perturbation theory. This method is effective because it considers the energy difference between the degenerate states and other states, suppressing the correction to the degenerate states at first order. The correction is then given by the expectation of the perturbation in the restricted degenerate subspace.
bananabandana
113
I'm struggling to understand degenerate perturbation theory. It's clear that in this case the 'normal' approximation method fails completely seeing as you get a divide by zero.
I follow the example for a two state system given in e.g D.J Griffiths "Introduction to Quantum Mechanics"
However, I don't understand the reasoning of how we go from that to say that we should generally "diagonalize the perturbation in the subspace of degenerate states" - how are we sure from the get go that the only significant contributions to the perturbed energy should come from the states which are degenerate in the original energy? Haven't we just completely excluded any others from consideration by this method?
Look at it this way:
Since the states are degenerate in the unperturbed system, there is no preferred basis of eigenvectors in the degenerate subsystem. You can therefore chose to work in the basis which diagonalises the perturbation in that subsystem. This will give you the zeroth order eigenstates.
Since the perturbation is now diagonal in the subsystem, you will have no problems applying first order perturbation theory to this set of states - the perturbation is diagonal in the degenerate subspace, indicating that the matrix elements (the ones that are divided by zero otherwise) are equal to zero. You therefore will find that the correction to these states appear at first order in perturbation theory and therefore are suppressed by the energy difference between the degenerate states and all other states. The first order energy shifts are, as usual, given by the expectation of the perturbation. In this case it just means the elements of the diagonalised restricted (to the degenerate subspace) perturbation.
If you will, consider it a move of the part of the perturbation that is in the degenerate subspace to the main Hamiltonian and consider the rest of the perturbation as the actual perturbation.
Likes vanhees71
Related to Degenerate Perturbation Theory
1. What is degenerate perturbation theory?
Degenerate perturbation theory is a mathematical method used to solve problems in quantum mechanics where the Hamiltonian (operator that represents the total energy of a system) has multiple degenerate states, meaning they have the same energy. It allows for the calculation of the energy levels and wavefunctions of a perturbed system by treating the degenerate states as a single entity and finding the corrections to their energies and wavefunctions.
2. What are the key assumptions of degenerate perturbation theory?
The key assumptions of degenerate perturbation theory are that the perturbed Hamiltonian is a small addition to the unperturbed Hamiltonian, that the degenerate states have the same energy in the unperturbed system, and that the perturbation is time-independent.
3. How does degenerate perturbation theory differ from non-degenerate perturbation theory?
In non-degenerate perturbation theory, the Hamiltonian has non-degenerate states, meaning they have different energies. This allows for a simpler calculation of the energy corrections and wavefunctions. In degenerate perturbation theory, the degenerate states must be treated as a group, which makes the calculations more complicated.
4. What are the limitations of degenerate perturbation theory?
One of the main limitations of degenerate perturbation theory is that it is only applicable to systems with small perturbations compared to the unperturbed Hamiltonian. Additionally, it is not accurate for highly degenerate systems or systems with large perturbations. It also does not take into account any interactions between the degenerate states.
5. How is degenerate perturbation theory applied in practice?
In practice, degenerate perturbation theory involves the use of mathematical techniques such as diagonalization and perturbation expansion to solve for the energy corrections and wavefunctions of the perturbed system. It is often used in quantum mechanics to calculate the energy levels and wavefunctions of atoms and molecules, as well as to study the effects of external fields on quantum systems.
  • Quantum Physics
  • Quantum Physics
