What Forces Affect Liquid Flow in a Circular Pipe?
In summary, the conversation discusses the forces at work to slow a liquid flowing in a circular pipe, specifically in the context of a torus pipe filled with a low viscosity liquid. The rotational flow pattern formed by the solid body rotation and the additional force of the solid container prevent the formation of free vortices. Viscosity also works to slow the flow, but other forces due to the circular flow geometry may also work against the momentum of the fluid. Vorticity can degrade kinetic energy trapped in circulation to heat and may diffuse the flow momentum in other ways. The axial pressure variation and body forces applied by the solid container may also degrade the flow and affect how quickly the momentum dissipates. The answer may be different if the pipe is
Carter Green
Hi I am trying to understand what forces are at work to slow a liquid flowing in a circular pipe
As an example the above torus pipe fully filled with an incompressible low viscosity liquid. This is rotated until the fluid achieves solid body rotation and then the pipe is suddenly stopped but the low viscosity allows the fluid to continue under its own inertia
I understand that a rotational flow pattern will be formed by the solid body rotation and the additional force of the solid container will prevent the formation of a free vortices ? is this correct ?
While I understand that viscosity works to slow the flow , are there other forces due to the circular flow geometry that work against the momentum of the fluid ?
Vorticity - degrades kinetic energy trapped in Circulation to heat ? Can it diffuse the flow momentum any other way ?
Can either
Axial Pressure Variation or -
Body Forces The additional force applied by the solid container degrade the flow (some version of Minor Losses in a pipe) effect how fast the momentum is dissipated ?
Additionally would the answer be different if the pipe wasn't fully filled with an incompressible liquid ?
Is there anything else I need to consider to how quickly the momentum would stop ?
Any readings that someone could recommend ?
I think that wall texture may be significant. At sufficiently high relative velocities, turbulence increases against a smooth wall whereas some wall textures (shark skin) can maintain laminar flow. It may seem counter-intuitive.
Below that critical velocity, it's all laminar flow.
Have you noticed how extreme your toroid image is? I expect the inner wall to have significantly less drag than the outer wall.
Your torroid is quite extreme, with far more surface area on the outside. However, the outside of the torus also has far more volume. Have you considered whether this differential drag on the volume of water may cause large vortices?
Another consideration is the Reynolds number. That is, at sufficiently high relative velocities, turbulence is generated at the smooth wall. The outside wall is going to have a higher relative velocity than the inner wall.
Have you considered wall texture? Shark skin has the counterintuitive property of maintaining laminar flow when a smooth wall would be throwing vortices.
Related to What Forces Affect Liquid Flow in a Circular Pipe?
1. What is the circular flow model?
The circular flow model is a simplified representation of the flow of goods and services, resources, and money between households and firms in an economy. It illustrates how these sectors interact and depend on each other in a continuous cycle.
2. What is degredation of the circular flow?
Degredation of the circular flow refers to the disruption or breakdown of the flow of goods, resources, and money within an economy. This can occur due to various factors such as economic crises, natural disasters, or policy changes.
3. How does degredation of the circular flow affect the economy?
Degredation of the circular flow can have negative impacts on the economy, such as a decrease in production and consumption, rise in unemployment, and decline in economic growth. It can also lead to imbalances in the flow of goods and services, causing inflation or deflation.
4. What are some examples of degredation of the circular flow?
Natural disasters, such as hurricanes or earthquakes, can disrupt the production and distribution of goods and services, causing a degredation of the circular flow. Economic crises, such as recessions or depressions, can also lead to a breakdown in the flow of money and resources within an economy.
5. How can degredation of the circular flow be addressed?
Degredation of the circular flow can be addressed through various measures, such as implementing economic policies to stimulate production and consumption, providing financial assistance to affected sectors, and investing in infrastructure to improve the flow of goods and services. It is important for governments and businesses to work together to address and prevent degredation of the circular flow in order to maintain a healthy and stable economy.
  • Other Physics Topics
  • Mechanics
  • Mechanical Engineering
