Degree of field extension
In summary: Q}]$. Keep in mind that the degree can be at most $8$ since it is the product of two degrees.In summary, you are trying to calculate the degree of the field extension $\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}$. This involves using the tower property and finding the minimal polynomial of $\rho$ over $\mathbb{Q}[\sqrt{3}]$. The degree can be at most $8$.
mathmari
MHB
5,049
Hey! :eek:I want to calculate the degree $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}]$.
It holds that $$[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\sqrt{3}][\mathbb{Q}[\sqrt{3}] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\sqrt{3}]]\cdot 2$$ and $$[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]][\mathbb{Q}[\rho] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]]\cdot 4$$ since we know that the polynomial $f=x^4-2x^2-1\in \mathbb{Q}[x]$ is irreducible, and $\rho\in \mathbb{C}$ is a root of $f$.
When we divide these two relations we get $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\sqrt{3}]]=2[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]]$.
From that we get that $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\sqrt{3}]]\geq 2$ and it is even, right? (Wondering)
It holds that $[\mathbb{Q}[\sqrt{3}, \rho]:\mathbb{Q}] \leq [\mathbb{Q}[\sqrt{3}] :\mathbb{Q}]\cdot [\mathbb{Q}[\rho] :\mathbb{Q}]$, or not? (Wondering)
Therefore, we get that
$[\mathbb{Q}[\sqrt{3}, \rho]:\mathbb{Q}]\leq 8$.
From $$[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]][\mathbb{Q}[\rho] :\mathbb{Q}]=[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]]\cdot 4$$
we get that $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]]$ is either $1$ or $2$. So $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\sqrt{3}]]$ is either $2$ or $4$.
How could we continue? (Wondering)
Hi there! It seems like you are trying to calculate the degree of the field extension $\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}$. This is an interesting problem that involves some abstract algebra and number theory.
First, let's define some terms. The degree of a field extension $L:K$ is denoted by $[L:K]$ and it represents the dimension of $L$ as a vector space over $K$. In simpler terms, it is the number of elements in $L$ that can be expressed as linear combinations of elements in $K$.
Now, let's take a closer look at your calculations. You correctly used the tower property of field extensions to break down the degree into smaller parts. This is a useful tool in determining the degree of a field extension. However, there are a few things to consider.
First, you mentioned that $f=x^4-2x^2-1$ is irreducible in $\mathbb{Q}[x]$. This is true, but it is also important to note that $\rho$ is a root of $f$ in $\mathbb{C}$, not in $\mathbb{Q}[\sqrt{3}]$. This means that $\rho$ does not necessarily belong to $\mathbb{Q}[\sqrt{3}]$ and we cannot simply use $[\mathbb{Q}[\rho] :\mathbb{Q}] = 4$. We need to find the minimal polynomial of $\rho$ over $\mathbb{Q}[\sqrt{3}]$ and use that to calculate $[\mathbb{Q}[\rho] :\mathbb{Q}[\sqrt{3}]]$.
Second, you mentioned that $[\mathbb{Q}[\sqrt{3}, \rho] :\mathbb{Q}[\rho]]$ is either $1$ or $2$. This is not necessarily true. It could also be $4$ since $\rho$ is a root of a degree $4$ polynomial.
To continue, you can try finding the minimal polynomial of $\rho$ over $\mathbb{Q}[\sqrt{3}]$ and use that to calculate $[\mathbb{Q}[\rho] :\mathbb{Q}[\sqrt{3}]]$. Then, use the tower property again to calculate $[\mathbb{Q}[\sqrt{3
FAQ: Degree of field extension
What is a degree of field extension?
A degree of field extension is a measurement of how much a field has expanded or increased in size. It is often used in mathematics and physics to describe the size or scope of a specific field.
How is a degree of field extension calculated?
The degree of field extension is calculated by comparing the size of the original field to the size of the expanded field. It is often expressed as a percentage or a ratio.
What factors can affect the degree of field extension?
The degree of field extension can be affected by various factors such as the strength of the initial field, the presence of other fields, and the properties of the medium through which the field is expanding.
What are some real-world examples of degree of field extension?
A common example of degree of field extension is the expansion of a magnetic field around a wire carrying an electric current. The degree of extension of the magnetic field will depend on the strength of the current and the distance from the wire.
Why is understanding degree of field extension important?
Understanding the degree of field extension is important in many fields of science, including physics, mathematics, and engineering. It allows us to accurately describe and predict the behavior of various fields, which can have practical applications in technology and everyday life.
