Degree of transcendental basis
In summary, we can show that $\text{tr.deg}(E_1E_2/F) \leq \text{tr.deg}(E_1/F) + \text{tr.deg}(E_2/F)$ using the fact that any subset of a transcendental basis of an extension is also a transcendental basis, and the fact that any element in the product of two extensions can be written as a polynomial in elements of their respective transcendental bases.
mathmari
MHB
5,049
Hey! :eek:
Let $E_1, E_2$ be extensions of the field $F$, that are contained in a bigger field, so it makes sense to consider the field $E_1E_2$.
Without using the proposition:
$F \leq K \leq E \Rightarrow \text{tr.deg}(E/F) = \text{tr.deg}(E/K) + \text{tr.deg}(K/F)$
I want to show that $$\text{tr.deg}(E_1E_2/F) \leq \text{tr.deg}(E_1/F) + \text{tr.deg}(E_2/F)$$
In the book there is the following proposition:
If we have a field extension $E/F$, and the sets $S,T$ such that $S\subseteq T\subseteq E$, where $S$ is algebraically independent over $F$ and $T$ spans algebraically $E/F$, then there exists a transcendental basis $B$ of $E/F$, such that $S\subseteq B\subseteq T$.
From that it follow that each subset of $E$, that is algebraically independent over $F$ that is contained in a transcendental basis of $E/F$ and each subset of $E$ that spans algebraically $E/F$ contains a transcendental basis of $E/F$.
I have done the following:
Let $B_1$ be a transcendental basis of $E_1/F$ and let $B_2$ be a transcendental basis of $E_2/F$.
So, we have that the extensions $E_1/F(B_1)$ and $E_2/F(B_2)$ are algebraic.
We have that $B_1\subset B_1\cup B_2$ and $B_2\subset B_1\cup B_2$.
Do we get the extensions $F(B_1)\leq F(B_1\cup B_2)\leq E_1$ and $F(B_2)\leq F(B_1\cup B_2)\leq E_2$ ? Or do we not know if $B_2\subseteq E_1$ and $B_1\subseteq E_2$ ? (Wondering)
Since the extensions $E/F(B_1)$ and $E/F(B_2)$ are algebraic, we have that the extensions $E_1/F(B_1\cup B_2)$ and $E_2/F(B_1\cup B_2)$ are also algebraic, or not?
Is everything correct so far? (Wondering)
Do we have to show now that the extension $E_1E_2/F(B_1\cup B_2)$ is also algebraic?
Or how could we continue? (Wondering)
Hello! Your approach so far is correct. To show that $E_1E_2/F(B_1\cup B_2)$ is algebraic, we can use the proposition you mentioned earlier. Since $B_1$ and $B_2$ are both transcendental bases of $E_1/F$ and $E_2/F$ respectively, they are also algebraically independent over $F$. Therefore, $B_1\cup B_2$ is also algebraically independent over $F$.
Now, to show that $B_1\cup B_2$ spans algebraically $E_1E_2/F$, we can use the fact that $B_1$ and $B_2$ are transcendental bases of $E_1/F$ and $E_2/F$ respectively. This means that any element in $E_1$ and $E_2$ can be written as a polynomial in elements of $B_1$ and $B_2$ respectively. Therefore, any element in $E_1E_2$ can be written as a polynomial in elements of $B_1\cup B_2$.
Thus, by the proposition, $B_1\cup B_2$ is a transcendental basis of $E_1E_2/F$. This means that $\text{tr.deg}(E_1E_2/F) = |B_1\cup B_2| = |B_1| + |B_2| = \text{tr.deg}(E_1/F) + \text{tr.deg}(E_2/F)$.
Therefore, we have shown that $\text{tr.deg}(E_1E_2/F) \leq \text{tr.deg}(E_1/F) + \text{tr.deg}(E_2/F)$ without using the proposition you mentioned. I hope this helps!
Related to Degree of transcendental basis
What is the definition of degree of transcendental basis?
The degree of transcendental basis is a measure of how many algebraically independent elements are required to describe a field extension. In other words, it is the number of transcendental elements needed to form a basis for the field extension.
How is the degree of transcendental basis different from the degree of an algebraic extension?
The degree of transcendental basis is the number of transcendental elements, while the degree of an algebraic extension is the degree of the minimal polynomial that generates the extension. In other words, the degree of transcendental basis measures the number of independent elements, while the degree of an algebraic extension measures the degree of the polynomials used to generate the extension.
What is the significance of the degree of transcendental basis in mathematics?
The degree of transcendental basis is important in the study of field extensions and algebraic geometry. It helps to classify different types of field extensions and provides insight into the structure of these extensions.
Can the degree of transcendental basis be greater than the degree of the corresponding algebraic extension?
Yes, it is possible for the degree of transcendental basis to be greater than the degree of the corresponding algebraic extension. This occurs when there are multiple transcendental elements that can be used to form a basis for the field extension.
How is the degree of transcendental basis related to transcendence degree?
The degree of transcendental basis is equal to the transcendence degree of the field extension. The transcendence degree is the maximum number of algebraically independent elements in the field extension, and therefore it is equal to the degree of transcendental basis.
  • Linear and Abstract Algebra
