Degree-Raising Formulas for Bernstein Polynomials
In summary, degree-raising formulas for Bernstein polynomials are mathematical expressions used to increase the degree of a polynomial by one without changing its properties. They work by manipulating the coefficients using linear algebra and calculus techniques. These formulas have applications in fields such as computer graphics and signal processing, but there are also limitations, such as only being able to increase the degree by one at a time. There are different types of degree-raising formulas available, each with their own advantages and limitations.
zodiacbrave
Two part question...
Question 1:
Let v = (a, b, c)T be a column vector which represents a coordinate vector of a polynomial in P2 with
respect to the Bernstein basis. Find the 4 × 3 matrix which transforms v to the standard basis of P3.
(Hint: First transform v to the standard basis of P2, then transform to the standard basis of P3 by just
adding an extra row of zeros.)
Question 2:
Multiply the matrix in the previous part (on the left) by the conversion matrix from the standard basis of
P3 to the Bernstein basis of P3. The resulting matrix should convert from degree 2 to degree 3 Bernstein
representation (degree-raising). Test your matrix on the Bernstein polynomials of degree 2. Check by
expanding everything back to the standard basis.
the Bernstein basis of P2 is { (t-1)^2, -2t(t-1), t^2}
the Bernstein basis of P3 is { -(t-1)^3, 3t(t-1)^2, -3t^2(t-1), t^3}
the change of basis matrix, from BB to standard is given by [1,0,0 ; -2,2,0 ; 0, 0, 1]
So, the question asks for a 4x3 matrix that will take a P2 Bernstein polynomial and transform it to p3 Bernstein polynomial.
So, the answer should be [1,0,0 ; -2,2,0 ; 0, 0, 1 ; 0, 0 ,0]
For question 2, I am to multiple the the matrix above with the matrix that goes from P3 (standard) to P3 (BB)
The matrix that goes from BB->S in p3 is [1,0,0,0; -3,3,0,0 ; 3,-6,3,0; -1,3,-3,1]^-1
so I multiple both matrices together and that should be the answer to question 2, right?
Thank you
for your question! I would approach this problem by first understanding the concepts involved and then solving the problem step by step.
For question 1, you are correct in your approach. To transform v to the standard basis of P3, you first need to transform it to the standard basis of P2 by using the change of basis matrix given. Then, you can simply add an extra row of zeros to get a 4x3 matrix that will transform v to the standard basis of P3.
For question 2, you are on the right track. However, when multiplying the two matrices, remember that the order matters. The matrix that goes from P3 (standard) to P3 (BB) should be multiplied on the left of the matrix you found in question 1. So, the resulting matrix would be [1,0,0,0; -3,3,0,0 ; 3,-6,3,0; -1,3,-3,1]^-1 [1,0,0 ; -2,2,0 ; 0, 0, 1 ; 0, 0 ,0]. This will give you the matrix that converts from degree 2 to degree 3 Bernstein representation.
To test this matrix, you can plug in the Bernstein polynomials of degree 2 and see if they are correctly transformed to the Bernstein polynomials of degree 3. You can also expand everything back to the standard basis to verify the results.
I hope this helps and good luck with your problem!
Related to Degree-Raising Formulas for Bernstein Polynomials
1. What are degree-raising formulas for Bernstein polynomials?
Degree-raising formulas for Bernstein polynomials are mathematical expressions used to increase the degree of a Bernstein polynomial by one without changing its shape or location. These formulas are important in numerical analysis and approximation theory.
2. How do degree-raising formulas work?
Degree-raising formulas work by using a combination of linear algebra and calculus techniques to manipulate the coefficients of a Bernstein polynomial. This results in a new polynomial with a higher degree, while preserving the same properties as the original polynomial.
3. What are the applications of degree-raising formulas for Bernstein polynomials?
Degree-raising formulas for Bernstein polynomials have various applications in fields such as computer graphics, signal processing, and numerical methods for solving differential equations. They are also useful in approximating complex functions and curves.
4. Are there different types of degree-raising formulas for Bernstein polynomials?
Yes, there are various types of degree-raising formulas for Bernstein polynomials, such as the Euler-Maclaurin formula, the de Casteljau algorithm, and the Cox-de Boor algorithm. Each formula has its own advantages and may be more suitable for certain applications.
5. What are the limitations of degree-raising formulas for Bernstein polynomials?
One limitation of degree-raising formulas is that they can only increase the degree of a Bernstein polynomial by one at a time. This means that multiple iterations may be necessary to achieve a desired degree. Additionally, these formulas may not work well for polynomials with very high degrees or for functions with complex behavior.
