Degrees of a Field Extension: How to Find Basis and Degree of a Field Extension
In summary, you found that $[\mathbb{Q}(\sqrt{2}):\mathbb{Q}]=4$ and that a basis could be $ \left \{ 1, i, \sqrt{2}, i\sqrt{2}\right \} $. You then utilised the tower law to find both $[\mathbb{Q}(\sqrt{2}, i ):\mathbb{Q} ]$ and $[\mathbb{Q}(\sqrt{2}):\mathbb{Q} ]$.
shmounal
Hi,
I've been asked to find $[ \mathbb{Q}(\sqrt{2}, i ): \mathbb{Q} ]$, and to write down a basis.
Now I know that $[ \mathbb{Q}(\sqrt{2}, i ): \mathbb{Q} ] = 4$, and that a basis could be $ \left \{ 1, i, \sqrt{2}, i\sqrt{2}\right \} $ it is whether the way I am explaining how I arrived here is satisfactory explanation.
Utilising the tower law I want to find both $[ \mathbb{Q}(\sqrt{2}, i ): \mathbb{Q(\sqrt{2})} ]$ and $[ \mathbb{Q}(\sqrt{2}): \mathbb{Q} ]$ and multiply.
For $[ \mathbb{Q}(\sqrt{2}): \mathbb{Q} ] = 2$ as $\mathbb{Q}(\sqrt{2}) = [a+b\sqrt{2} | a,b \in \mathbb{Q}]$ so $\mathbb{Q}(\sqrt{2})$ is a 2d vector space over $\mathbb{Q}$ with basis $\left \{1, \sqrt{2}\right \}$
I then use a similar argument for $[ \mathbb{Q}(\sqrt{2}, i ): \mathbb{Q(\sqrt{2})} ] = 2$ in that $\mathbb{Q}(i)(\sqrt{2}) = [a+bi | a,b \in \mathbb{Q(\sqrt{2})}]$
and the rest follows. I'm not sure if this is enough to show it rigidly. Some of my friends have been using minimal polynomials to show the different degrees and I don't entirely follow the logic!
Any help appreciated!
xx
Certainly you should justify why $[\mathbb{Q}(\sqrt{2}): \mathbb{Q}]=2$ . As $\sqrt{2}\not\in \mathbb{Q}$ , then $[\mathbb{Q}(\sqrt{2}): \mathbb{Q}]>1$ , but $p(x)=x^2-2\in\mathbb{Q}[x]$ satisfies $p(\sqrt{2})=0$ , so $p(x)$ is the minimal polynomial of $\sqrt{2}$ and a basis of $\mathbb{Q}(\sqrt{2})$ over the field $\mathbb{Q}$ is $\{(\sqrt{2})^0,(\sqrt{2})^1\}=\{1,\sqrt{2}\}$ . In the same way , $i\not\in\mathbb{Q}(\sqrt{2})$ , then ...
Thanks for the help! Think I understand now.
What I was doing only showed that the degree was 2 or more while finding the min polynomial says it must be exactly 2?
i.e. $p(x) = x^2 + 1 \in\mathbb{Q} (\sqrt{2})[x]$ satisfies $p(i) = 0$, ...
Right, that is the question.
Also right.
another way to show that [Q(√2):Q] = 2 is to show that {1,√2} generate Q(√2), to do this, you need to prove that every element of Q(√2) is of the form a+b√2 (i.e. that the set of all such elements with a,b in Q does indeed form a field, and this field is contained in any field that contains Q and √2).
finding an irreducible polynomial of minimal degree is often easier, because of the isomorphism Q(√2) ≅ Q[x]/(x^2 - 2). note that proving x^2 - 2 is irreducible over Q is the same as showing √2 is irrational, something often glossed over as "obvious" and stated without proof. a similar consideration holds for i, and to be really nit-picky, showing x^2+1 is irreducible over Q(√2)[x] one ought to appeal to the fact that Q(√2) is a sub-field of the reals, which has no square roots of negative numbers (a consequence of being a totally ordered field).
when one has a cubic (or higher) extension, the polynomial approach really shines, because then one knows that successive powers of a root (up to one less than the degree of the minimal polynomial, in this case: 2, since we have a cubic) are linearly independent (or else the root would have a minimal polynomial of lesser degree). so the polynomial itself provides the basis.
FAQ: Degrees of a Field Extension: How to Find Basis and Degree of a Field Extension
What is a field extension?
A field extension is a mathematical concept that involves extending a field (a set of numbers with specific operations) by adding new elements to it. This allows for the creation of a larger field with more complex numbers.
How are degrees of a field extension determined?
The degree of a field extension is determined by the number of elements that are added to the original field. For example, if the original field is the set of rational numbers and we add the square root of 2, the degree of the extension is 2 because we only added one new element.
What is the significance of degrees of a field extension?
The degree of a field extension is important because it helps us understand the complexity of a field. A higher degree of extension means that the field contains more complex numbers, which can be useful in solving certain mathematical problems.
Are there any limitations to field extensions?
Yes, there are some limitations to field extensions. For example, not all fields can be extended. Additionally, some fields may have a finite degree of extension, while others may have an infinite degree.
How are field extensions used in real-world applications?
Field extensions have many applications in various fields, including physics, engineering, and computer science. They are used to solve complex mathematical problems and to represent real-world phenomena, such as electromagnetic fields and fluid dynamics.
