MHB Degrees of Vertices IV: Graph is a Tree?
  • Thread starter Thread starter Joystar77
    Degrees
For the graph G with vertex set V = {v1, v2, v3, v4, v5} and vertex degrees of 1, 2, 1, 3, and 1, the calculation shows that E = 4, which satisfies the condition of having n-1 edges for a tree. However, it is emphasized that G must also be a connected graph to qualify as a tree. A graph can have n-1 edges yet still be disconnected, thus not meeting the criteria for being a tree. Therefore, while the edge count is correct, connectivity must also be established to confirm G as a tree. The discussion highlights the importance of both edge count and connectivity in determining if a graph is a tree.
Joystar77
Let G be a graph with vertex set V = {v1, v2, v3, v4, v5}.
If the degrees of the vertices are 1, 2, 1, 3, 1, respectively, is G a tree? Why or why not?
2E = deg v1 + deg v2 + deg v3 + deg v4 + deg v5
2E = 1 + 2 + 1 + 3 + 1
2E = 8
E = 4
Yes, the degrees of vertices 1, 2, 1, 3, 1, G is a tree because the number of edges should be n-1 where n is the number of vertices.
Is this correct?
2E = 8
E = 4
Is this correct?
Not bad. But you also need to show that $G$ is a connected graph. There can exist a graph on $n$ vertices which is disconnected (thus not a tree) and has $n-1$ edges. So just by virtue of having $n-1$ edges a graph doesn't become a tree. It needs to be connected too.
Thank you Caffeinemachine!
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
