Del operator in spherical coordinates
In summary, the del operator in spherical coordinates can be found using various methods such as using the chain rule to change variables and expressing the cartesian unit vectors in terms of the spherical unit vectors. The process may be complicated, so it is recommended to explore different methods and choose the one that is most suitable for the given problem.
tirwit
Write the del operator in spherical coordinates?
I wrote the spherical unit vectors:
[tex]\hat{r}[/tex]=sin[tex]\theta[/tex].cos[tex]\phi[/tex].[tex]\hat{x}[/tex]+sin[tex]\theta[/tex].sin[tex]\phi[/tex].[tex]\hat{y}[/tex]+cos[tex]\theta[/tex].[tex]\hat{z}[/tex]
[tex]\hat{\phi}[/tex]=-sin[tex]\phi[/tex].[tex]\hat{x}[/tex]+cos[tex]\phi[/tex].[tex]\hat{y}[/tex]
[tex]\hat{\theta}[/tex]=cos[tex]\phi[/tex].cos[tex]\theta[/tex].[tex]\hat{x}[/tex]+sin[tex]\phi[/tex]+cos[tex]\theta[/tex].[tex]\hat{y}[/tex]-sin[tex]\theta[/tex].[tex]\hat{z}[/tex]
I have no idea where to start... Please help, I'm going crazy with this...
In cartesian coordinates, you have
[tex]\nabla = \hat{x} \frac{\partial}{\partial x}+\hat{y} \frac{\partial}{\partial y}+\hat{z} \frac{\partial}{\partial z}[/tex]
Use the chain rule to change variables to [itex]r, \varphi, \vartheta[/itex]. For example, you can write
[tex]\frac{\partial}{\partial x} = \frac{\partial r}{\partial x}\frac{\partial}{\partial r}+\frac{\partial \varphi}{\partial x}\frac{\partial}{\partial \varphi}+\frac{\partial \vartheta}{\partial x}\frac{\partial}{\partial \vartheta}[/tex]
Then express the cartesian unit vectors in terms of the spherical unit vectors. Plug everything in and simplify.
It seems I suggested one of the more painful ways of finding the gradient.
Here's a web page that describes several different methods you can try:
http://math.mit.edu/classes/18.013A/HTML/chapter09/section04.html
Related to Del operator in spherical coordinates
1. What is the Del operator in spherical coordinates?
The Del operator, represented by ∇, is a mathematical operator used in vector calculus to calculate the gradient, divergence, and curl of a vector field. In spherical coordinates, it is given by ∇ = (1/r)∂/∂r + (1/r sinθ)∂/∂θ + (1/r sinθ)∂/∂φ, where r, θ, and φ are the radial, polar, and azimuthal coordinates, respectively.
2. How is the Del operator used in spherical coordinates?
In spherical coordinates, the Del operator is used to calculate the directional derivatives of a scalar or vector function in three-dimensional space. It can also be used to express other vector calculus operations, such as the Laplacian operator, in spherical coordinates.
3. What is the gradient in spherical coordinates?
The gradient of a scalar function ƒ in spherical coordinates is given by ∇ƒ = (∂ƒ/∂r)er + (1/r)(∂ƒ/∂θ)eθ + (1/rsinθ)(∂ƒ/∂φ)eφ, where er, eθ, and eφ are the unit vectors in the radial, polar, and azimuthal directions, respectively.
4. What is the divergence in spherical coordinates?
The divergence of a vector field A in spherical coordinates is given by ∇·A = (1/r2)(∂(r2Ar)/∂r) + (1/rsinθ)(∂(sinθAθ)/∂θ) + (1/rsinθ)(∂Aφ/∂φ), where Ar, Aθ, and Aφ are the radial, polar, and azimuthal components of A, respectively.
5. What is the curl in spherical coordinates?
The curl of a vector field A in spherical coordinates is given by ∇×A = (1/rsinθ)(∂(sinθAφ)/∂θ - ∂Aθ/∂φ)er + (1/r)(∂Aφ/∂r - ∂(rAr)/∂φ)eθ + (1/r)(∂(rAθ)/∂r - ∂Ar/∂θ)eφ, where Ar, Aθ, and Aφ are the radial, polar, and azimuthal components of A, respectively.
