Delayed Choice Quantum Erasers
In summary, the delayed choice quantum eraser experiment involves entanglement between a "signal" photon and an "idler" photon. The signal photon's interference pattern is altered depending on whether the idler photon is detected at one set of detectors or another. This does not require backwards in time influences, but rather the first measurement of the signal photon influences the probabilities of the subsequent detection of the idler photon at different locations. The Copenhagen interpretation suggests that the collapse of the wave function alters the probabilities of the idler photon's detection, creating interference patterns.
Jarwulf
31
I'm a very thickheaded layperson so be warned, I'll probably require a lot of patience.
Anyway, I'm having a very difficult time understanding the delayed choice quantum eraser experiments. It seems to me that it is implying that either the idler photon is going back in time and changing the signal photon or the signal photon is somehow determining how the idler photon will behave. Yeah you don't see interference fringes in the overall pattern but doesn't that simply mean that the interference pattern is still there, just hidden among all the other subsets?
Also does the copenhagen or any other nondeterministic/agnostic interpretations have an explanation that prevents the need for backwards time travel?
I speculated about this on another recent thread:
The delayed choice quantum eraser involves the "signal" photon that goes through the slits being entangled with an "idler" which can tell you which slit the signal photon went through if it goes to one set of detectors (D3 or D4 in Scully's paper) but this information will be lost if it's detected at a different set of detectors (D1 or D2). If the signal photons are detected first, then you could use the 2-particle wavefunction for the signal/idler pair to calculate the probability distribution for just the signal photon to end up at different points on the screen; if the idlers are detected first, then according to the standard procedure for calculating probabilities this would cause a discontinuous collapse in the 2-particle wavefunction which would alter the probabilities of the signal photon landing at different points on the screen. However, I presume that if you calculate P(signal photon detected at position X|idler detected at detector D1)*P(idler detected at detector D1) + P(signal photon detected at position X|idler detected at detector D2)*P(idler detected at detector D2) + P(signal photon detected at position X|idler detected at detector D3)*P(idler detected at detector D3) + P(signal photon detected at position X|idler detected at detector D4)*P(idler detected at detector D4), then you should get almost exactly the same answer as you'd get for P(signal photon detected at position X) in the case where the signal photon is detected first so there was no prior state reduction in the 2-particle wavefunction caused by the detection of the idler (I say almost exactly because there may be cases in which the idler just misses all 4 detectors, but you should be able to make it exact by adding additional detectors so that there was no possible direction the idler could go without hitting a detector).
Likewise, if the signal photon is detected first, in the standard Copenhagen picture I imagine this would collapse the 2-particle wavefunction in a way that changes the probability the idler will end up at different detectors--if the signal photon is detected at a position that's near a peak of the D1/D0 interference pattern and a trough of the the D2/D0 interference pattern, that should increase the probability that the idler will go to D1 and decrease the probability it'll go to D2, for example.
Jesse you saying nothing in complicated way - means you know not answer. Why bluffing eh?
Yes the fringes are "hidden" in the detections at D1 and D2.
They only become visible if you consider the coincidence counter information to match either of those sets against detections at D0.
I don't see how you got that the idler photon is going back in time.
The photon will either arrive at D1/D2 (where the which-path information is erased) or it will arrive at D3/D4 (where the which-path information has been preserved).
If that which-path information is preserved, you can't very well see an interference pattern just like the regular quantum eraser experiment without a delayed choice.
Specifically, that which-path information is attained by collapsing the wave function (Copenhagen interpretation).
The wave function needs to be in tact for it to interfere with itself and cause the pretty fringe lines.
http://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser
http://en.wikipedia.org/wiki/Quantum_eraser_experiment
Jarwulf's question was how you could explain the interference patterns in a way that doesn't require backwards in time influences. I gave an answer to that--if you measure the signal photons at D0 first, their probability distribution will be a non-interference pattern, but this causes a wavefunction collapse which alters the probability that the idlers go to different detectors in such a way as to create a D0/D1 interference pattern and a D0/D2 interference pattern. No backwards-in-time influences needed here, just the first measurement of the signal photons influencing the probabilities of the subsequent detection of the idlers at different locations.
Okay if I'm reading correctly its detection of the signal photon/its location which influences which detectors the idlers will end up with.
but isn't the signal photon measured before the idlers reach the first beamsplitter?
Before the idlers for D1 and D2 reach the second beamsplitter the only difference between them and the D3+D4 idlers is the path they take after BSa or BSb. How would a photon 'know' what detector to go to preserve or remove its which-path information based on what location its signal counterpart ended up at?
In quantum physics you can't really imagine that the photons are taking any definite path until they are measured--think of the normal double-slit experiment, where if you look at the pattern on the screen created when you cover up the second slit (so you know all the photons went through the first slit) and then you look at the pattern created if you cover up the first slit (so you know they went through the second), the sum of these two patterns is not what you get if you leave both slits open simultaneously (and don't measure which slit they went through). In QM you assign the particle a wavefunction which involves a superposition of different possible positions (including the positions corresponding to all the different possible paths), and only when you measure the particle do you assume it will be found at a definite location, with the probability of it being at a given position being equal to the square of the "amplitude" the wavefunction assigns to that position. For an entangled system you have a two-particle wavefunction which assigns amplitudes to all combinations of positions for the particles, and then if you measure one of the particles (like the signal photon) this causes a sudden jump in the wavefunction which alters the amplitudes of finding the other particle at various positions.
Related to Delayed Choice Quantum Erasers
What is a delayed choice quantum eraser?
A delayed choice quantum eraser is an experiment in quantum mechanics that involves the measurement of entangled particles and the retroactive determination of their properties.
How does a delayed choice quantum eraser work?
In a delayed choice quantum eraser experiment, entangled particles are sent through a series of beam splitters and detectors. The detection of one particle's property at a later time can determine the property of its entangled partner, even if the partner has already been measured and its property seemingly determined.
What is the significance of delayed choice quantum erasers?
Delayed choice quantum erasers challenge traditional notions of causality and suggest that the act of measurement can affect the behavior of particles in the past. This has implications for our understanding of the nature of reality and the concept of time.
What is the role of entanglement in delayed choice quantum erasers?
Entanglement is a phenomenon in which two or more particles become connected in such a way that the state of one particle can affect the state of the other, regardless of distance. In delayed choice quantum erasers, entanglement allows for the retroactive determination of particle properties.
How are delayed choice quantum erasers being used in research and technology?
Delayed choice quantum erasers have been used in various experiments to explore the behavior of particles and the concept of time. They also have potential applications in quantum computing and cryptography, as well as in enhancing our understanding of quantum mechanics and the nature of reality.
