Delocalisation stability - primarily an entropy or enthelpy issue?
In summary, the stability of delocalised RCOO- ions compared to RO- ions, leading to the difference in acidity between RCOOH and ROH, is driven more by entropy changes rather than enthalpy changes. This is due to the greater ordering of water by RO- ions compared to RCOO- ions, resulting in a larger difference in ΔS and, ultimately, a larger ΔG. The difference in gas phase proton transfer energies also supports this conclusion.
Miffymycat
47
This question was prompted by reflecting after reading the standard textbook explanation that "the greater acidity of RCOOH vs ROH is due to the greater stability of the delocalised RCOO- ion causing the position of equilibrium to be further to the right". The equilibria can be written as:
RCOOH(aq) ⇄ RCOO-(aq) + H+(aq) Eq 1
ROH(aq) ⇄ RO-(aq) + H+(aq) Eq 2
It seems an oversimplified explanation. Charge delocalisation clearly means entropy is increasing from more electron disordering and enthalpy is decreasing from lower mutual repulsion forces. However, we aren’t just comparing the theoretical stability of delocalised RCOO-(g) vs RO-(g), but the Kc for an overall process in aqueous solution. Taking simple example typical values:
pKa of ethanoic acid = 4.8; pKa ethanol = 16, both assumed at 298K.
ΔGϴ = -RTlnKc gives ΔGϴ(Eq 1) = +27 kJ mol-1 and ΔGϴ(Eq 2) = +91 kJ mol-1
Using ΔG = ΔH – TΔS, the enthalpy component of ΔG should be a function of the difference in O-H bond energies in RCOOH(aq) and ROH(aq) and their respective anion hydration energies. These values for RCOOH would be expected to be lower on both counts (due to the presence of the carbonyl group withdrawing electron density), but their sum cannot be easily predicted. H-bonding in aqueous solution will also have a different effect. Some literature values are approximately
ΔHhydration CH3COOH = -9kJ mol-1 and ΔHhydration C2H5OH = -11kJ mol-1
Even accepting some variation in these data, and that the enthalpy changes for Equations 3 & 4
CH3COOH(l) ⇄ CH3COOH(aq) Eq 3
C2H5OH(l) ⇄ C2H5OH(aq) Eq 4
are included in these values, it still means that Equation 2 must have a significantly more negative ΔS to account for its larger ΔG, one assumes from greater ordering of water by RO- than by RCOO- due to its greater charge density / lower delocalisation / higher entropy. I cannot find any data to quantify this aspect, but from the signs and magnitudes of ΔG and ΔH it appears we can say that the delocalisation stability which gives rise to the differing pKa’s is indeed driven more by entropy changes rather than enthalpy changes! Any one like to agree or disagree?!
Chemistry news on Phys.org
:cry: What's wrong with your computer, hasn't it got any apostrophes? - I mean line intervals.
But gosh, you look to be right! Solvation rules! This has been concluded from results on proton transfer in the gas phase. Compared to the 64 kJ mol-1 difference between dissociation from ethanol or acetic acid you mention, the difference in the gas phase is just 5 kJ mol-1.
And even that little is the wrong way round! :smile:
You can find some detail about this issue in Howard Maskel, The physical Basis of Organic Chemistry. My edition is 1985, there may be more recent, but the discussion is clear and it seems a definitive conclusion.
Related to Delocalisation stability - primarily an entropy or enthelpy issue?
1. What is delocalisation stability?
Delocalisation stability refers to the ability of electrons in a molecule to be distributed or shared over multiple atoms, rather than being confined to a single atom. This can lead to increased stability and lower energy states in the molecule.
2. Is delocalisation stability an entropy or enthalpy issue?
It can be both. Entropy refers to the degree of disorder in a system, and delocalisation can increase disorder by spreading out the electrons. Enthalpy, on the other hand, is a measure of the total energy of a system, and delocalisation can also decrease the overall energy of a molecule, making it more stable.
3. How does delocalisation stability affect chemical reactions?
Delocalisation stability can affect the rate and outcome of chemical reactions. In molecules with delocalised electrons, the electrons are more easily shared between atoms, making it easier for bonds to break and form. This can lead to faster and more favourable reactions.
4. Can delocalisation stability be predicted?
Yes, delocalisation stability can be predicted using theoretical models and calculations. The degree of delocalisation can be estimated based on the molecular structure and the properties of the atoms and bonds involved.
5. How does temperature affect delocalisation stability?
Increasing temperature generally leads to increased delocalisation stability. This is because higher temperatures increase the energy of molecules, allowing them to overcome energy barriers and achieve more delocalised states. However, at very high temperatures, delocalisation stability may decrease due to the breaking of bonds and loss of molecular structure.
13K
  • Mechanical Engineering
24K
28K
