Delta fuction potential general solution
In summary: You would write that as ρ = q \delta (x) \delta (y) \delta (z) . You will write it in that way so that ∫ \rho dV over the whole space gives you the result q. But ρ must have units coulomb per volume, but in your formula you have coulombs in q , so delta functions have units 1/length.
Danny Boy
49
Hi, in the book 'Introduction to Quantum Mechanics' by Griffiths, on page 71 in the section 'The Delta-Function Potential' he states that the general solution to time independent Schrodinger Equation is $$\psi(x) = Ae^{-\kappa x} + B e^{\kappa x}$$
he then notes that the first term blows up as $$x \to -\infty,$$ so we must choose $$A=0.$$ Why is it that we are rejecting a wave function that goes to infinity? Is it simply because we are looking for normalizable solutions?
Thanks.
For ##x<0## you must choose ##A=0## and for ##x>0## you must have ##B=0##, if ##\kappa>0##. That's indeed, because you want to have bound states in this case, leading to normalizable wave functions. Note that there may be solutions with ##\kappa \in \mathrm{i} \mathbb{R}##, leading to scattering states with energy eigenvalues in the continuum, and these wave functions are generalized eigenfunctions that are "normalizable to a ##\delta## distribution" only.
Likes Danny Boy
So my reasoning is correct then that we want normalizable solutions hence the requirement that the wave function is bounded?
If you restrict yourself to the bound-state solutions, it's correct.
Okay thanks. One quick question, do you maybe know why the delta function is said to have units 1/length?
Simple explanation: in electrodynamics when you want to write (for example) charge density function for point charge in the origin. You would write that as ρ [itex] = q \delta (x) \delta (y) \delta (z) [/itex] . You will write it in that way so that ∫ [itex] \rho dV[/itex] over the whole space gives you the result [itex] q[/itex]. But ρ must have units coulomb per volume, but in your formula you have coulombs in [itex] q [/itex], so delta functions have units 1/length
Likes vanhees71 and Danny Boy
Related to Delta fuction potential general solution
1. What is a delta function potential?
A delta function potential is a mathematical function that is used to model a potential energy in quantum mechanics. It is a localized potential that is represented by a delta function, which is a mathematical function that is zero everywhere except at one point, where it is infinite.
2. How is the general solution of a delta function potential determined?
The general solution of a delta function potential is determined by solving the Schrödinger equation, which is the fundamental equation of quantum mechanics. The solution involves finding the appropriate boundary conditions and applying them to the delta function potential to obtain the wave function.
3. What are the properties of the delta function potential?
The delta function potential has several important properties, including being infinitely tall at the point where it is defined, and being zero everywhere else. It is also symmetric about the origin and has a finite area under the curve, despite being infinite at a single point.
4. How is the delta function potential used in physics?
The delta function potential is used in physics to model various phenomena, such as the potential energy of a particle in a one-dimensional system, or the potential energy of a particle in a bound state. It is also used to model interactions between particles, such as in nuclear physics and quantum field theory.
5. Are there any real-world examples of a delta function potential?
Yes, there are several real-world examples of a delta function potential. One example is the potential energy of an electron in an atom, where the electron is bound to the nucleus by a delta function potential. Another example is the potential energy of a particle in a one-dimensional box, which is used to model the behavior of particles in a confined space.
  • Quantum Physics
  • Quantum Physics
